95 tacoma reg cab leaning to left
Old Nov 30, 2013 | 02:57 PM
BigHoss_27's Avatar
If I look at back of truck it leans pretty noticeably to the left when I bought it it just had new rear leafs put on would a bad shock make it lean? And I got on rear bumper bounced on each side and the side that's leaning over isn't as springy and the other side. Much help appreciated
Sent from my DROID RAZR using YotaTech
Old Nov 30, 2013 | 03:18 PM
HighLux's Avatar
Diet?
Let your springs settle in.
Old Nov 30, 2013 | 03:45 PM
BigHoss_27's Avatar
What does a diet have to do with it? I've only had it road worthy a week and guy before me could have only been 170 soaking wet and it does it with 2 people in the cab and corners diff in left and right handers
Old Nov 30, 2013 | 03:59 PM
HighLux's Avatar
I was kidding. Let the springs settle in. After new leafs....it takes time for them to relax into final ride height. If you mess with anything now....it will just change. Once settled in....then adjust.
Old Nov 30, 2013 | 04:07 PM
BigHoss_27's Avatar
So that would cause 2-4 inch difference between sides?
Old Nov 30, 2013 | 04:13 PM
HighLux's Avatar
No....thats either a bad install...or wrong springs.
Get some pictures of this leaning Tower of Toyota for us. Get underneath...shots of springs...shackles...etc..
Old Nov 30, 2013 | 04:23 PM
BigHoss_27's Avatar
I will asap
Old Nov 30, 2013 | 05:21 PM
Bigblock's Avatar
Mine does it too but I dont care! I drive the hell out of it anyway. LOL Most likely the front spring is the culprit.
Old Nov 30, 2013 | 05:28 PM
BigHoss_27's Avatar
The front isn't bad its just the rear I think its a junk shock on rear driver side just seeing what you guys think and like I said the passenger side feels more springy then the driver side
Old Nov 30, 2013 | 11:17 PM
wyoming9's Avatar
Red face
Could be they only did the right side and being newer sits higher.
got the wrong spring
just a bad spring that flattens out.
A bad shock unless it is the wrong one should not effect ride height.will have the truck handle very poor.
although strange things do happen
jasonty
41
Dec 23, 2018 01:00 PM
94whiterunner
Jul 12, 2015 07:15 PM
Seattle_Sign_Guy
Jul 12, 2015 12:38 PM
Poncho0206
Jul 10, 2015 06:21 PM
Cplmike
Jul 8, 2015 08:47 PM
