Alignment out of wack!
Old Nov 15, 2013 | 04:48 AM
fibercarbon's Avatar
Exclamation Alignment out of wack!
I took my 1997 4runner sr5 V6 to get an alignment and they said It was so bad that I needed to replace all the parts in the front. I was wondering what exact parts I need to do this properly.
Old Nov 20, 2013 | 05:57 AM
hrt4me's Avatar
ITRs and OTRs to start
Old Nov 20, 2013 | 07:16 AM
hilgeg's Avatar
Get it up on jack-stands or a rack and spend some time pushing, pulling, and shaking your tires. See what moves. Might want a second opinion from another shop to see if they will tell you what is loose. I just had upper and lower control arm bushings cause alignment issues for me, but I've seen tie-rod ends (mentioned by hrt4me), ball joints, and steering rack cause issues. Good luck! May want to let the audience here know if you are running a lift of any sort, mileage, and what you have replaced for a more accurate reply.
ladybugRC
458
Aug 21, 2020 10:41 AM
stanz
Oct 30, 2015 10:33 AM
voiddweller
Sep 28, 2015 11:21 PM
gyroscope7
Sep 21, 2015 04:55 AM
gyroscope7
Sep 13, 2015 05:15 AM
