Help me with my timing belt
Old Dec 8, 2013 | 11:20 AM
Basnbuks's Avatar
Replacing my timing belt and water pump after pump locked up and it jumped time., i bought a dayco kit that has everything, my question is were do i get my slack from to slip belt on , i havnt released the pin yet on the hyd tensioner but when i slide belt on and just tighten up the tensioners it pulls my timing marks off. Is there a trick to this or do i just compensate and keep trying
Old Dec 8, 2013 | 02:13 PM
pettybilt's Avatar
Are you working on a 3.4? The belt should have marks on it to align it to the cam gear and crank. I don't remember having any issues on mine. The belt should slip on ,as long as the marks are lined up, pull the pin. Should be good.
Old Dec 8, 2013 | 04:03 PM
blandis's Avatar
I just did mine earlier today on the 3.4. I took the top roller loose, very loose, and once I had it across the cam gears correctly, went slow and snugged up the top roller.
I could not get mine under the roller without loosing it. Once on and ready to go pull the pin on the tensioner.
Old Dec 8, 2013 | 04:40 PM
Basnbuks's Avatar
Yes 3.4, im aware of marks and all but when i tightend up the rollers my marks on cam were lined up , but marks on belt were off a couple teeth, i went thru this a couple times. Said screw it as long as all marks line up it dont matter were marks on belt are.only way i could slip belt on was to loosen both rollers. Its all good she fired rite up
Eggslinger
Jun 8, 2019 03:32 PM
thefishguy77
Jul 30, 2015 10:59 AM
nick b
Jul 11, 2015 04:38 AM
Huntingtruckcletus
Jul 8, 2015 05:26 PM
