2.7 3rz timing chain
Old Nov 11, 2013 | 02:31 PM
BigHoss_27's Avatar
Way to tell if it jumped tooth without removing cover and head? Please help
Sent from my DROID RAZR using YotaTech
Old Nov 12, 2013 | 05:27 AM
raretaco02's Avatar
Does it run , the only real way is by the sound of it when it is turning over to start . If it does run ,is there any loss of power . One guy put a piece of paper over the exhaust pipe but I don't know how to determine it that way but the those motors ain't real bad for jumping time.
Old Nov 12, 2013 | 05:46 AM
BigHoss_27's Avatar
I think I may have did it when doing head gasket
Old Nov 12, 2013 | 06:05 AM
raretaco02's Avatar
Oh well does it run or jus turn over ,weak or what
Old Nov 12, 2013 | 06:09 AM
BigHoss_27's Avatar
See I haven't got it all back together yet so I think it may be best to just bite the bullet and and take it off and check
Old Nov 12, 2013 | 06:17 AM
raretaco02's Avatar
What is making you think that is out of time ???
Old Nov 12, 2013 | 06:49 AM
BigHoss_27's Avatar
Hand cranked motor and it gets to a point and locks up and I think I herd it jump on sprocket
Old Nov 12, 2013 | 08:10 AM
raretaco02's Avatar
Very good poss it is out but I don't know that you could have really done it by hand ? Are you sure it was in time when the tensioner was out ? During assembly? But if there is nothing external stopping it from turning the that's what it is . I really hope u didn't warp a valve ,cause I have done it just like you did before .
Old Nov 12, 2013 | 08:14 AM
HighLux's Avatar
Take it apart. Only way to be sure now. You will always worry until you do it.
Old Nov 12, 2013 | 08:19 AM
raretaco02's Avatar
I know it sucks to do it twice but if it was me I would have the head ( valves) checked too
Old Nov 12, 2013 | 09:15 AM
BigHoss_27's Avatar
I found the problem bolt was keeping it from turning and cam was hitting it and getting stuck is it hard to make it jump timing with a wrench and socket
Old Nov 12, 2013 | 09:32 AM
raretaco02's Avatar
Its not impossible but it would take one hell of hit I doubt u done it by hand
Old Nov 12, 2013 | 09:40 AM
BigHoss_27's Avatar
The key way on crank shaft is pointing to tdc also right?
Old Nov 12, 2013 | 10:50 AM
raretaco02's Avatar
Not sure on the 2.7 Buddy I'm a vz man
Old Nov 12, 2013 | 11:10 AM
BigHoss_27's Avatar
I'll pull front dully and look at key way
Old Nov 13, 2013 | 07:19 AM
raretaco02's Avatar
Did you get her put together yet
Old Nov 13, 2013 | 08:04 AM
BigHoss_27's Avatar
Timing looks right when I get time I'm gonna pull off pully and see if keyway is straight up to number 1 cyl but on tdc can marks is straight up to the block cause motor sits crocked in truck
Sep 4, 2015 09:27 AM
thefishguy77
Jul 30, 2015 10:59 AM
razorman8669
Jul 12, 2015 12:13 PM
