Circuit Open Relay on '98 4runner
Old Dec 30, 2013 | 03:42 PM
MMc's Avatar
MMc
I think it's somewhere behind the glove box, but I can't find it. I've searched here for pictures and I can find them for other generation 4runners but not 3rd.
My problem is that my 4runner won't crank. The starter seems to be turning over fine, but it won't fire. Has been running with no issues at all and after it's been sitting since I parked it on Saturday but today (Monday) it wouldn't crank.
I checked the battery and fuses and don't see an issue. The fuel pump was replaced less than 6 months ago...
Any thoughts or ideas?
Old Jan 3, 2014 | 03:20 AM
wyoming9's Avatar
Red face
Nope it is in the fuse block on the left side.
on the bottom .
Has your MIL come on and have you pulled the codes??
Old Jan 3, 2014 | 01:35 PM
reaj's Avatar
Had the same problem one random day it won't start, crank and crank but nothing. No spark either it was off and on symptoms for me. Finally bit the bullet and had it towed to an auto eletric place here in denver. Turns out I had a short in the main wire harness that runs behind the dashboard. Cost me 700 for them to diagnose, find, repair, and put it all back together. That was 2 years ago and haven't had an issue since. Take a look at a FSM manual anything you would ever need will be in there. My problem was probably more complicated then what you have hopefully!
Regency
20
Jan 3, 2020 07:43 PM
Doug4320
Mar 24, 2018 10:11 PM
coryc85
Sep 9, 2015 06:24 AM
Johntom240
7
Jul 13, 2015 12:18 AM
colinmil
Jul 6, 2015 04:03 PM
