PDA
View Full Version : 95.5-2004 Tacomas & 96-2002 4Runners
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 [99] 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222
  1. relplace muffler on 96 4runner?
  2. air intake mod ok for emissions?
  3. A+ for tmc1.1
  4. 22re to a v6
  5. OME u-bolts
  6. about fed up with 3.0l v6
  7. New Yok's on a 91 2nd Gen
  8. Pick-your-part and atestiment to Toyotas
  9. rear diff is making a whine noise
  10. 05 4Runner Limited rattle/vibration
  11. arb turn signal wiring
  12. 3rd gen rear sag?
  13. anyone know the part number for this?
  14. hitch?
  15. how much does your first gen v6 weigh?
  16. whats next?
  17. How much did you pay for your Runner?
  18. Will they fit ? Tires that is.....
  19. My left hadn side cv after i when mudding
  20. Steering wheel alignment
  21. 3rd Gen Tundra Brakes Parts
  22. Thanks Guys
  23. help!! vacuum hose missing....
  24. "Missing bolt"
  25. Lug nut question
  26. Tranny Fluid confusion: 2.x quarts or 4 quarts??
  27. breaks
  28. Random e-Brake light?
  29. loose idler pulley
  30. Clutch adjustment
  31. Engine Miss/Check engine light - Possibly TPS?
  32. Diesel oil in a gas engine??
  33. Dual stage thermo?
  34. HOw do you get rid of annoying idle situation
  35. Toyota recall...with a catch?
  36. PA/East Coast G2G
  37. Inspect head gasket for recall work
  38. 87 4Runner - Best Way to Fix Leaking Sunroof
  39. Canadian Denso Dealers
  40. drive train slack. ....seems excessive
  41. Low fuel light sending unit?
  42. Questions on 89 Ext. cab auto
  43. 2000 tacoma question
  44. Dual cat. converter 4runners
  45. Gauge Help
  46. Sticky Door Switch
  47. 30 tacoma trd sway bar size...
  48. Issue with leaking Rear driver side axle seal...
  49. Are there different types of heads for 22re?
  50. Steering stabilizer or new tie rods for 3rd gen
  51. in-dash switch for stock port
  52. I'm nearly official! Buying 4runner today.
  53. Bull bar question again.
  54. major problems-transmission
  55. Problem starting engine - 5spd
  56. Timing Belt +?
  57. Check Engine Light: Where to look next
  58. Recomended Tranny Fluid
  59. In the market for a used 4Runner...what to look for?
  60. Air conditioning question - 89 Toyota
  61. Urgent Help Needed, stalling 3rd gen SC
  62. i need to know my size
  63. 2nd Gen Out Of Surgery-Total Chaos/fiberglass
  64. turn signal assembly
  65. First gen\third gen wheel tire swap.
  66. Finding King's Spanner Wrench
  67. Looks like it's going to be a long weekend! *pics*
  68. SAW Trouble, HELP.
  69. Fender flares for 96 sr5 with no trim
  70. my 4wd doesnt work?????
  71. Brand New Starter choice....
  72. What to check for in Front Diff quality?
  73. 2nd Gen Rear Bumper
  74. IFS Parts Interchange
  75. Tacoma OEM Flex hose p/n (brake line extension)
  76. SR5 oil pressure gauge questions
  77. still can't get ahold of marlin crawler
  78. 22RE Rod bearing/rebuild opinions and a few other Q's
  79. Going back to stock - Need stock front bumper
  80. Funny noise from dashboard.
  81. 96 Rear Door latch broke?
  82. unichip programmer for S.C. 3.4l
  83. Synthetic or oil
  84. drop steps
  85. Waterpump or thermostat?
  86. parts for an 81?
  87. Someone Help! Fan's driving me nuts!
  88. Cone or cup?
  89. my 25year old 20R Compression results...
  90. Sea Foam
  91. Taking care of Yotatech
  92. What Is The Ring Gap For A 22R?
  93. Where does the o2 sensor wire go?
  94. 85K miles on my S/C
  95. 2 tow hooks while keeping the valance
  96. tire question
  97. my new Toy!
  98. CB placement, 1st Gen
  99. throttle sticking-help
  100. Is it possible to get something like this that fits a 3rd gen?
  101. Struts done, now a couple coil wrap Q's
  102. Airlift 1000 replacing swaybar?
  103. Supra Seat Conversion in Hilux Surf
  104. Liquid head gasket repair?
  105. Success!!!
  106. TJM T13 Installed
  107. A few pics from the weekend
  108. Need Help with AC electrical
  109. Opinions and questions for wheel experts?
  110. What is the best 4runner for under $10K ???
  111. Replacing Drive Belts
  112. low oil pressure
  113. dealer tells me my water pump leaks....sometimes.
  114. original Toyota wheels... looking for a set of plain white rims with hubcap clips..
  115. a note to 4crawler
  116. I'm finally getting a toyota... a quick hello and a few questions.
  117. Purchasing 3rd gen soon, what mod's should i do?
  118. Vortex Muffle
  119. automatic transmission problems
  120. What is a stinger?
  121. best shock and tire for a stock '80 4x4
  122. will 2.5" exhaust hurt my engine?
  123. body swap? sorry i had to do it
  124. Changing from Carb to EFI
  125. Shipping from engnbldr to Canada
  126. Second Skin Tacoma: Sound deadening Work in progress
  127. New Heads for 22R
  128. Belt Replacement
  129. Snorkel
  130. Need help diagnosing check engine code
  131. Re-badging my truck
  132. need yakima wind fairing mounts
  133. Third row seat
  134. Help! Key stuck in ignition...
  135. Fuel Gauge Issue?
  136. what happens when switching from 16" rim to a 15"?
  137. Intercooler vs. cold air intake w/supercharger
  138. Basic 3.4L question--recommended oil filter?
  139. Quick IFS question
  140. A few minor problems I need help with
  141. VSC and Check light
  142. Question about 1991 Toyota Automatic Transmission
  143. engine swap 22r for a 3vze
  144. weird wot problem and gearing question
  145. Where to mount cb in toyota truck
  146. Knock in '89 3.0 V6
  147. Timing Chain 2.7?
  148. rancho?
  149. Headlight/Taillight Problem
  150. Am I the only one who likes RED?
  151. Finally got the lift on!!!!!!!!!!!!!
  152. Gas tank/sensor/gauge problem???
  153. Stock '91 Tire Carrier
  154. tach problems
  155. Picture Request
  156. Transfer Case/5spd Tranny Leak
  157. Low compression, is the Head a problem on 22re?
  158. U joint or differental issues?
  159. Antenna mount is loose...
  160. 22re flywheel torque specs?
  161. I need 4 tires 4 4Runner 4 cylinder no 4 wheel 4 choices??
  162. hub/rattle/noise/annoying
  163. URGENT: Body mount help
  164. need immediate help!! permanent marker on paint
  165. Emergency Brake Cable
  166. '88 4Runner - what color wires come out of wiring harness for O2 sensor?
  167. Stupid mistake w/ battery
  168. green cruise light wont go off
  169. wish I had the money
  170. Off roading adventures
  171. finally got around to cleaning & waxing again
  172. Switched to Syn today.....
  173. Loud creaking sound at full lock?
  174. very odd happenings under the hood, please help.
  175. Towing with 91 std cab. 22RE?
  176. Time to sell the 2nd gen 4runner
  177. Gettin new tires - Quick Question??
  178. DOA Heads
  179. Help Cracking the Code(s)
  180. P0171 troubles (bank 1) - redux
  181. OK when is the snow gonna get here?
  182. New 88 4Runner purchaser with a couple questions
  183. Need a lil help with keyless/andlights
  184. Do you like your brush guard?
  185. ...and a nice high 3rd gen
  186. ...more toys
  187. various toy pics
  188. lifted 2000 4runner, weird noises!!!!
  189. Does a header really improve the 20r's performance?
  190. clutch questions
  191. tachometer on non-tach truck
  192. removing hubs to get wheels off?
  193. strange rattling noise around the front passenger side kickplate
  194. 3.7 1st gen
  195. Alternator/Gauge Reading
  196. '93 P/U dash for '91 4Runner?
  197. add on gauge questions
  198. Drive shaft hitting gas tank. What to do?
  199. Does anybody have pics of their header flanges?
  200. skippin out?
  201. Different Rancho Shocks for L and R rear?
  202. Need Guinea Pig - Found Cheap 1st Gen Cupholder
  203. Modifying Exhaust Header
  204. "rattling noise” from Catalytic
  205. All those mileage questions
  206. 88 pickup running hot
  207. New to a 96 4Runner limited, Front end issues
  208. Catch Can?
  209. Oxygen Sensor not connected to anything?!?
  210. Quick Boot?
  211. Acetone to improve MPG by 30%
  212. NO POWER the horn doesn't even work!! HELP!!
  213. 4-Runner/Truck Frame Swap?
  214. How steep have you gone??
  215. OME 891 or OME 890 rear springs
  216. OME springs, which side?
  217. Stoplight switch wire, 03 Taco, where?
  218. Early Christmas for me
  219. Starter for 3vz 1990
  220. New Cargo Storage / Bed in 4Runner
  221. Vote for Wheelin'!
  222. rough shifting gears
  223. Please help :think:
  224. High idle for a long time after start
  225. is there a recall for the 1980 20R exhaust manifolds?
  226. Rebuild 3VZE 3.0L V6
  227. 1990 Toyota V6 problem
  228. 3.4 hesitation
  229. o2 sensor
  230. 4wd, first time in awhile!
  231. TaDaaa! Found the problem... Update on previous losing my mind post..
  232. Gas door and cap
  233. having gauge cluster/light problems
  234. power seats in an '89 p'up
  235. hub install in progress now
  236. evap hoses- locations- please
  237. 2nd Gen Squeal when letting clutch out
  238. Noise coming from engine: timing chain?
  239. tire wear
  240. 3.4 timing question
  241. 3rd Gen truck - wet okole impressions.
  242. The new Toyota FJ Cruiser might make me trade my 4Runner in...
  243. headers
  244. 2nd Gen Lexus V8 swap anyone?
  245. where to find a bumper
  246. 3rd gen front bumper question
  247. Help with tire selection for East Coast wheeling
  248. High mount 3rd brake light on a 1st gen 4Runner?
  249. Great oil pressure at start up.
  250. Another 302 Swap thread
