Please help :think:
Old Sep 9, 2005 | 02:59 AM
2003mikem's Avatar
Please help :think:
Yesterday I was going to work, driving to work my check engine light came on. I dropped my truck of at my normal shop.
I called them and they told me they could scan it. The shop called me and said they could not scan. But they said the problem is the air pump is disconnected, I told them that that is the a/c pump. Then they said the fuel return lines are not hooked up, again I told them that the hose was for the rear heater.
I brought the truck to a trans shop and they could scan it for me. It has a code “52” which is a short circuit or open circuit with the knock sensor. Any ideas or wiring diagram? There is no adnormal noise from the engine. Just the normal from the injectors. Since the light came on I seem to have a power lose. It might just be in my head.When I see lights it makes me paranoid
PLEASE HELP
Old Sep 9, 2005 | 03:19 AM
Ironmike4x4's Avatar
Check to see if the knock sensor is unplugged, frayed or even cut.
Old Sep 9, 2005 | 03:20 AM
2003mikem's Avatar
where is it ?
Old Sep 9, 2005 | 03:22 AM
I'm not sure on the top of my head, maybe someone else here will chime in. If I get time at work I will look it up and post it.
Old Sep 9, 2005 | 05:22 AM
GreeneHoosier's Avatar
It depends on your truck, but it is generally on the side of your block, My 22r had it on the pass side, low to the rear just above the oil pan lip. I hope this helps.
Old Sep 9, 2005 | 05:23 AM
2003mikem's Avatar
my 1991 4runner has a 3.0 v6
Old Sep 9, 2005 | 05:28 AM
Hmmm... I have never seen a 3.0 torn down (lucky, I guess) so I cannot say for sure. It will ALWAYS be on the block, though and usually low, not too hard to find on the 4 cyl's. It is round and has 1 or two wires connected, it is about 19mm, I think.
Old Sep 9, 2005 | 06:02 AM
90's Avatar
90
The knock sensor on 3vze is on the top of the block under the intake.
http://personal.utulsa.edu/~nathan-buchanan/93fsm/
Look under "engine block", you'll see a diagram
Old Sep 9, 2005 | 06:07 AM
SloPoke's Avatar
Read this thread...
https://www.yotatech.com/forums/show...0+knock+sensor
and this one...
https://www.yotatech.com/forums/f2/knock-sensor-wire-3vz-e-34186/
Lots of knock sensor info on this board.
I couldn't come up with alot of micrgrounding info but it's definately something that can't do any harm and may just work.
Old Sep 15, 2005 | 12:52 PM
ketman's Avatar
I have a 3.0 V6 and the same problem. The knock sensor is under the intake manifold. I'm about to replace mine. The wire that goes to it is on the driver side next to the firewall, or it could come from a spot between the injectors on the driverside of the engine, so someone told me at Toyotanation.com Check your connection, it maybe loose and good luck. I wish I had a four cylinder. I got a huge job ahead of me. Ketman
Old Sep 15, 2005 | 12:57 PM
LittleRedToyota's Avatar
can't help with the knock sensor issue, but, for future reference, you can easily "scan" the ECU codes yourself with a paper clip. here is a write-up on how:
http://www.off-road.com/toyota/tech/codes/index.html
Old Sep 17, 2005 | 01:15 PM
Bigblock's Avatar
Its Just The Wire Not The Sensor ,but You'll Still Have To Remove The Upper And Lower Intake
Obmi
Oct 30, 2015 04:27 PM
superjoe83
Mar 3, 2004 10:52 AM
superjoe83
Feb 27, 2004 01:11 AM
