Modifying Exhaust Header
Old Sep 9, 2005 | 12:44 PM
skier's Avatar
A couple of weeks ago I ordered a Pacesetter header from Summit and it came today. The header has round holes for the older style head despite coming with documentation for a 1990-1995 and coming with a gasket with pear shaped holes in them. There is a hole right where the top of the pair is (bolt hole? in the header). Would it cause a noticeable change in performance if I simlpy welded over this hole?
I emailed summit about the issue and they emailed me (an obviusly standard message) about sending back the item prepaid. Great, first I pay lots of money to have it shipped here, pay customs, and have to ship it back. Not only that, but I have to wait for more parts to come in so my downtime is longer. Not really a good solution. Fixing the damn thing would be better for me.
I was thinking about just blocking the whole and perhaps grinding out a bit of the metal to make the whole slightly better shaped. Would this work and be a good solution?
Old Sep 9, 2005 | 12:46 PM
dwh91102's Avatar
I know it sucks, but if it was me I would send them back for the right ones.
Old Sep 9, 2005 | 01:30 PM
4Crawler's Avatar
Wonder if you need the block-off plates like I have on my '85:
There are two small holes below each end of the plate.
Old Sep 9, 2005 | 02:21 PM
skier's Avatar
Roger,
that's exactly what I need now that I go look at it. However, now that I look even closer, there was a copper pipe that went across and took the place of the block of plates.
Thanks all. I was pretty frusterated and wasn't thinking all that well.
Old Sep 9, 2005 | 02:26 PM
4Crawler's Avatar
You probably have the later style external EGR plumbing that fits over those plates. I have the earlier style that runs the exhaust gas back inside the head.
Old Sep 10, 2005 | 10:26 PM
maxxjq's Avatar
i just got the same header installed today and did you have a really annoying sound coming from the header before you put those bolts in the middle of the one-two pipes and three-four pipes? because my truck is really annoying right now. if that is all i need to do in order to make it good then i will be very glad
Old Sep 10, 2005 | 10:31 PM
bob200587's Avatar
I've never heard a good word about pacesetter.....you get what you pay for in this case i'd say....thats just my and many other peoples opinons tho...whatever works.
Old Sep 10, 2005 | 11:26 PM
maxxjq's Avatar
will putting bolts in the empty holes help the sound at all?
justdifferentials
Just Differentials
Jun 13, 2022 07:40 PM
Zach_trun
Jan 22, 2020 04:42 PM
Corvoid
Dec 11, 2015 11:21 AM
DiggnDeep
Sep 3, 2015 02:45 PM
