Dual stage thermo?
Old Sep 16, 2005 | 08:04 AM
mightyhye's Avatar
Question Dual stage thermo?
Does anyone know if a dual stage thermostat is available for the 3.0 V6?
-shawn
Old Sep 16, 2005 | 06:52 PM
mightyhye's Avatar
bump! does anybody know?
thanks
Old Sep 16, 2005 | 07:00 PM
WATRD's Avatar
Okay, educate me, I have to know...
I have never heard of a "dual stage" thermostat. What the heck is it? A regular thermostat doesn't exactly snap open and snap closed, there's some in between. And I would infer that a "dual stage" thermostat had two open positions, a fully open and a partially open. But since a standard thermostat has some degree of variabilty, what would be the benefit?
Old Sep 16, 2005 | 07:18 PM
mightyhye's Avatar
Rob,
From the brief research that I've done, the dual stage t-stat has two valves in it, one bigger at the regular temp. and one smaller on at a cooler temp. If the bigger one stays shut and fails to open, the smaller one stays open.
I hope I am understanding this correctly, but I hear that it makes for a more accurate and fail safe thermostat. I know a few people on this forum have used one on their 4 cylinders with great success, but I haven't yet heard of anyone using it on the 3.0.
I need to change my thermo and wanted to get the better of the two if their is one.
Old Sep 16, 2005 | 07:22 PM
4Crawler's Avatar
Here's the info on the part:
- http://www.4crawler.com/4x4/CheapTri...tml#Thermostat
And the single-valve (left) and the dual-valve (right) and the gasket (bottom):
Not sure if it'll fit the V6 or not. Measure and post the OD of the t-stat and compare that with the 4-cyl part OD (52mm).
The main advantage is the smaller valve can resond to temp. changes faster than the larger valve (basic thermodynamics). So it fine tunes the coolant temp while the large valve handles the big changes.
Old Sep 16, 2005 | 07:36 PM
WATRD's Avatar
Interesting and very cool. Thanks for the education guys You learn something every day.
Old Sep 16, 2005 | 07:46 PM
mightyhye's Avatar
thanks 4crawler. I actually bookmarked your cheap tricks page and I referenced it when Rob asked me the question. When I take my old one out, I'll measure the OD and check it against the dimension you gave me for the dual stage that you used.
thanks again for the help!
Old Sep 17, 2005 | 02:30 PM
highway74's Avatar
I'm interested to find out as well, I'm in need of a new one.
Old Sep 18, 2005 | 08:51 PM
mightyhye's Avatar
has anyone tried a dual stage in a 3.0? I know they work great in the 22R, but I was wondering if there are any horror stories or success stories while using one in a 3.0.
-shawn
kawazx636
Oct 6, 2021 03:03 PM
voiddweller
Oct 2, 2015 07:47 AM
Toys4parts
Sep 26, 2015 01:56 PM
toyotasaurus
Sep 24, 2015 03:30 PM
noahstancik
Sep 10, 2015 10:47 AM
