Timing Belt +?
Old Sep 15, 2005 | 06:54 AM
ohio4runner4x4's Avatar
Question Timing Belt +?
I sent several requests to some Toyota parts places asking what else I should be changing when I do the timing belts on both of my 4Runners...Here's what they say and their prices....wondering what you guys think?
1- t/belt 13568-69095 $ 36.68ea
1- t/belt tensioner pulley 13505-62070 $85.55ea
1- t/belt idler pulley 13503-62040 $ 63.79ea
2- Cam seals 90311-38051 $ 7.15ea
1- crank seal 90311-40022 $ 5.15ea
1- water pump 16100-69398-83 $ 94.00ea
1- thermostat 90916-03075 $ 12.15ea
1 -thermostat gasket 16325-62010 $ 3.68ea
1- a/c belt 99364-20870-78 $ 17.90ea
1- alt belt 90080-91090-83 $ 6.86ea
1- pw. st. belt 99364-21070-83 $ 5.98ea
Old Sep 15, 2005 | 07:19 AM
DH6twinotter's Avatar
Hey!
Sounds about right, although I don't know if you need to replace the tensioners. When I did my timing belt, I didn't replace the tensioners becuase mine were still in good condition. If they say yours are bad, then yes, replace them. All depends on thier condition, or if you just want a little peace of mind knowing they are new, you can go ahead and do them anyways.
Cranks seal would be a good idea. I didn't do mine, but I just didn't feel like bothering with it since I had never done it before and mine isn't leaking. It's not much more labor, so you can go ahead and get it done.
Not sure on the Cam seals. Some people say you have to take the cam sprockets off to do the timing belt, but I didn't. So, I didn't bother and mine were not leaking. Not sure the procedure that the Toyota dealerships use, so I don't know if they would charge you more for labor or not.
Water pump and thermostate and thermostate gasket--yes.
All the various belts need to be replaced anyways, so you might as well have new ones on.
The list you had looks pretty good. I don't think they are trying to rip you off or anything. Since you are getting it fixed at the dealership, you may want to have everything replace so you don't end up paying for it later.
Well, that's about it. Have fun all.
Daniel
BTW, those prices seem pretty good. Looks lower than list price.
Old Sep 15, 2005 | 09:57 AM
Exclamation
Thanks for the reply.....but I think I confused you......I had asked the parts people what all I should change when I do my timing belt and the list is what they said. The prices are for the parts only...no labor! I'm gonna do it myself!
Old Sep 15, 2005 | 10:02 AM
snap-on's Avatar
I see no reason for the cam seals and crank seal.
My thermostat came with a gasket so i didnt need a new one.
you will mostlikely need the tensioners. I would replace them as you cant get to them easly in another 10-20K.
Upper and lower hoses
silicone gasket maker
Old Sep 15, 2005 | 04:05 PM
Oh, sorry, I did missunderstand that. If your oil seals aren't leaking, than no need to replace them. I think the cam sprockets are a pain to get off anyways. So, just do the waterpump, timing belt, and the thermostat. Like snap-on said, the thermostat gasket comes with the waterpump. I forgot about the gasket maker. I didn't do the pulleys because mine were fine, but it would probably be a good idea for you to do them. I think mine had been done once before in the past anyways.
Have fun on that crank bolt. It's a pain.
Well, that's my $.02.
Have fun all.
Daniel
Eggslinger
Jun 8, 2019 03:32 PM
thefishguy77
Jul 30, 2015 10:59 AM
nick b
Jul 11, 2015 04:38 AM
Huntingtruckcletus
Jul 8, 2015 05:26 PM
