Waterpump or thermostat?
Old Sep 14, 2005 | 12:08 AM
mightyhye's Avatar
Question Waterpump or thermostat?
If I overheat at idle after a couple of minutes but cool back down when moving, which do guys think it could be, waterpump or thermostat? How could I test either one?
I just replaced the fan and fan clutch for the third freakin time and am desperate to try something else to see if it will stop the overheating. Truck didn't overheat before i decided to change the old and somewhat leaky fan clutch (which was probably engaged all the time).
thanks,
shawn
Old Sep 14, 2005 | 12:16 AM
jimbo74's Avatar
is the water boiling, getting warm, or what? if it is boiling, stop driving it, head damage will occur...
Old Sep 14, 2005 | 12:17 AM
Elton's Avatar
i would try a thermostat first to test it u have to boil it in some water to
what ever temp it is if it opens its fine
Old Sep 14, 2005 | 12:18 AM
jimbo74's Avatar
jsut htought of something else... there are ways to test the thermostat... or jsut replace it, they are cheap..... my truck didnt have a thermostat when i got it... ran cool until summer..... then it started getting hot...... from the research i did... it was becasue the water was actually flowing through the system so fast because there was no thermostat, that it wasnt in the radiator long enough to cool down
Old Sep 14, 2005 | 08:12 AM
mightyhye's Avatar
bump cause I need some serious help!
Old Sep 14, 2005 | 08:16 AM
DudeBud's Avatar
touch the bottem hose when the motor is hot and see if the hose is cold if it is then the tstat is crap.had the same problem ended up being the tstat
Old Sep 14, 2005 | 02:22 PM
Nic's Avatar
Nic
It might be the thermostat or water pump. The thermostat is easy enough to replace. It could be neither. Your radiator may be partially clogged. Just thought I would throw that in.
kawazx636
Oct 6, 2021 03:03 PM
wberry85
May 17, 2016 05:45 PM
White Stripe
Oct 6, 2015 10:47 AM
rmill05
Sep 27, 2015 01:43 PM
LotOMiles
Sep 14, 2015 11:45 PM
