Clutch adjustment
Old Sep 16, 2005 | 09:51 AM
ssbogger's Avatar
Clutch adjustment
The clutch pedal on a 2002 tacoma has about an inch of play in it before it starts to engage the clutch. Is there a way to tighten this up?
Old Sep 13, 2007 | 03:28 PM
apalmer1's Avatar
on the pedal itself there are two adjustments. the first is a bumpstop on the lever which adjusts the height, the second is a pushrod that goes into the master cylinder. In your case you may either have to just lower the pedal height by extending the bumpstop, or you could try adjusting the pushrod to gain more pressure. Maybe a combination of both.
To adjust the height there should just be a locking nut and another nut the moves the rod. For the plunger on teh master cylinder there is a pin that slides through a fork and a hold in teh pedal arm, this is held inplace by a clip. Remove the clip, slide the pin out. Hold the not on the rod itself with an open end wrench and use another wrench to loosen the locking nut( in this case you tighten it to back it off, so righty loosy) , then twist the plunger rod in farther or out more.
Old Sep 13, 2007 | 05:29 PM
Yota Doc's Avatar
Dang you guys are fast. Yea whut he said.
Old Sep 13, 2007 | 06:54 PM
Ian Rogers's Avatar
hey do you own a FSM it outlines all of this... i think it was the best 120 i spent 3 books all about my truck
he's gone
7
Dec 3, 2019 07:08 AM
89fourrunner
Feb 17, 2016 06:52 AM
akamon808
3.4 Swaps
Dec 16, 2015 08:45 PM
Shaun Crystal Gomban
Jul 30, 2015 10:13 PM
1996Taco
Jul 20, 2015 12:02 AM
