throttle sticking-help
Old Sep 13, 2005 | 04:07 PM
trainerdude's Avatar
well, problem number 2 in the past week. my 99 sr5's throttle is sticking. basically, when i push on it gets stuck about half way down about 75% of the time. if i release it part of the way and immediately push back down it sometimes lets me past the sticking point but not all the time. when i mess with the throttle cable in the engine it seems fine. i assume that it has something to do with the accelerator. has anyone experienced this problem? if not, anyone have any ideas? thanks
seth
Old Sep 13, 2005 | 05:06 PM
Elton's Avatar
try lubeing the cable may be clean the throttle body ?
Old Sep 13, 2005 | 05:24 PM
Rick F.'s Avatar
From: Far western Kentucky (transplanted from central PA)
I was thinking throttle body, but that usually causes the butterfly to stick on initial opening but you never know. Cleaning the throttle body couldn't hurt. If it's not that, I'd look for someplace the cable may be binding. There are good write-ups in the tech section on cleaning the TB.
Old Sep 14, 2005 | 06:03 AM
it was cleaned last spring but i will definitly give it a try. thanks for your help. i'll let you know if it works
Old Sep 14, 2005 | 10:12 AM
well, that didn't help. i cleaned the throttle body and lubed the hell out of the accelerator assembly. now what???
Old Sep 14, 2005 | 11:24 AM
Is it something simple like the pedal sticking to the floor mat or the pedal assembly (not sure if this is what you meant by accelerator assembly)
Old Sep 14, 2005 | 05:02 PM
i think it is the pedal assembly. i know its not sticking to the floor mat. i thought that it was at first but i ruled that out right away. who know? i guess i'll see what the machanic says tomorrow. thanks for all the suggestions.
some drunk guy
Aug 3, 2021 06:09 PM
the_supernerd
Oct 1, 2015 09:20 PM
shredder4286
Oct 1, 2015 01:09 PM
Sam hain
19
Sep 30, 2015 08:25 AM
Shaun Crystal Gomban
Sep 20, 2015 11:16 PM
