Switched to Syn today.....
Old Sep 10, 2005 | 02:59 PM
2000t4r's Avatar
I swapped out all of my old fluid for Amsoil 75-90 gear oil in the front and rear diff and the transfer case. I also had the tranny flushed with the BG machine and had them install BG syn tranny fluid.
Overall I'm happy with the difference that it has made, seems to shift smoother. Though I did have one question I was only able to get about 2 qts of fluid in the rear diff, is this common? The book called for 2.6.
While I was under there I changed my oil and did a little clean up.
I only had one problem we destroyed the drain plug on the front diff. Seemed like someone put that thing on with an impact gun (I know that you can't really). Ended up getting it off and replaced it with a new one.
Old Sep 10, 2005 | 09:00 PM
02SE's Avatar
When replacing gear oil in any of the components that use it, the vehicle must be level, front-to-back, and side-to-side.
If the vehicle isn't level, you will either get too much, or too little gear oil in the respective component.
Was your vehicle level?.
Old Sep 11, 2005 | 12:14 AM
2000t4r's Avatar
Yes it was on a lift and level
Old Sep 11, 2005 | 06:43 PM
2000t4r's Avatar
Bump for some other opinions
Old Sep 11, 2005 | 08:51 PM
Stock02's Avatar
If you put oil in up to the fill hole yer fine.
kawazx636
Oct 6, 2021 03:03 PM
beltcutter
Sep 30, 2015 06:14 AM
PNW94Runner
Sep 29, 2015 02:55 PM
charlie_fong
Sep 27, 2015 10:06 PM
runnermedic
13
Sep 21, 2015 05:20 PM
