Struts done, now a couple coil wrap Q's
Old Sep 13, 2005 | 03:23 PM
Broncrick's Avatar
Been lurking (and learnig) for years, first post
Just did my front struts (shocks) on my 99 Taco. Two quick Q's....
Why is there 8 coil wraps on the drivers side and 9 coil wraps on the Pass? seems the dia is the same. Wonder if they were swapped at one point helping the 'Taco Lean' ? diff rates? no I didnt take the compr clamps off and compare the heigths
Since I did the struts I have read to have a Hunter mchn align the front end. Why? seems all I did was change 'shocks' and not change the geometry any.
Enlighten me, new to IFS chit
Old Sep 14, 2005 | 05:20 AM
jvangun's Avatar
The extra wrap for the drivers side is to compensate for the gas tank, I think.
Old Sep 14, 2005 | 11:32 AM
i would say the same.
A simple search gave this example:
https://www.yotatech.com/forums/show...iver+side+coil
Old Sep 14, 2005 | 01:46 PM
Broncrick's Avatar
Tried search and never found that thread, thanks! Guess I have to pull them once again
Old Sep 14, 2005 | 01:50 PM
ASU4runner's Avatar
Should be 9 coil winds on the driver side, and yes due to the weight from the gas tank.
Old Sep 14, 2005 | 02:03 PM
Broncrick's Avatar
Thanks, just went out to look for colors/stampings/tags, nada. Makes perfect sense to me, PO (or shop) switched 'em.
Now back to the alignment Q ? if the geometry didnt change why align, unless it is just an accepted practice
smthwsn357
May 1, 2024 07:28 AM
Sleaker
Aug 26, 2020 06:03 AM
Peevedkitten
11
Aug 31, 2015 06:57 PM
viesail
Aug 17, 2015 08:39 PM
izzmee
Aug 17, 2015 10:20 AM
