PDA
View Full Version : 95.5-2004 Tacomas & 96-2002 4Runners
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 [134] 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222
  1. Guess who got water in their intake...
  2. Wana' Great Deal On Tires And Wheels
  3. Local tire shop (NYC area)
  4. Engine Oil for 3.4 v6
  5. 96 3rd Gen Sidemarker lights
  6. changing light in headlight on 1st gen
  7. where is it leaking from???
  8. fuel injection and straight axle
  9. Shell V-Power° sucks!!!
  10. Cheap alternative to HID (worth reading)...
  11. Uh Oh...whats this??
  12. Driveshaft Question, will a 2nd gen fit a 3rd?
  13. ISR break-in time?
  14. fender flares??
  15. Sounds like pads are gone... but they're new!?
  16. Brake warping at 20000 miles! Is this normal?
  17. What Octane do you run and why?
  18. VSC light, searched but couldn't find
  19. Tundra Clutch Noise
  20. Replacement switch for rear window?
  21. Light Mounts-fabbing
  22. Rear End Clunck
  23. 93 2WD Auto - Horrible/Violent Shaking/Vibration, Please help!!
  24. 36 mm Ø nut in front axle
  25. 265/70-17 spare on 4th generation 4Runner?
  26. URD fuel kit finally installed...
  27. Maybe looking for some parts...
  28. Injector Rebuild Kits
  29. quiet high flow muffler?
  30. TPS adjustment
  31. keyless beep beep
  32. I'm almost ready to sell my runner. What would you do?
  33. Anyone have a 1998 4runner with factory keyless entry?
  34. 22RE Cam....
  35. Taco 5" lift - still rubs?
  36. California OHV Permit
  37. New Exhaust help 22RE
  38. anyone looking for a 4runner?
  39. Snaking a power wireeee through firewall
  40. 2nd gen w/ updated bumper?
  41. Rotors!
  42. 93 2WD TRUCK: adding P/S
  43. How many people's front springs have the same # of winds as the 99s?
  44. Tranny problems...syncros....
  45. Fuel filter
  46. V6 fuel economy ??
  47. Rear Window Scratching on 3rd Gen
  48. how do you wire trailer hitch?
  49. ? on Heavy Duty Springs, '02 Taco TRD 4x4
  50. Let me get this straight:
  51. What trans fluid to use?
  52. HELP QUICK--Tire Fitment on Rim ?
  53. Anyone with a 2nd Gen Toyota Factory Repair Manual...PART 2
  54. Post with lift measurements?
  55. knock when turning steering wheel
  56. 2nd gen locking fuel door > not locked
  57. How much methyl hydrate do I use?
  58. So I'm driving home the other day when all of a sudden
  59. Locked hubs on highway?
  60. wheel bearing and rotor replacement!
  61. 2.7 to 3.4
  62. !!!Problem!!!
  63. Hood scoops-Factory Option?
  64. 2005 Tacoma Double Cab Test Drive !!!
  65. Next Step???
  66. Speedo recalibration?
  67. winter tires
  68. Did you get a bigger spare when upsizing tires?
  69. how to: dual exhaust?
  70. Ignition timing question
  71. IFS Locker????
  72. Gosh Darn CV!
  73. manual hub spring and bearing?
  74. Increasing Gas Mileage?
  75. 3.4 Idle Speed
  76. Pics of My Destroyed Rear Diff - Causes?
  77. Did the '99 Highlanders.....
  78. Which Tires?!
  79. Starter 2nd Gen
  80. I own a 3.0 Gen 2 4Runner, Where's My Coolant Temp Sensor
  81. Won't start. Need help
  82. Upping gear ratio with LSD? (for towing)
  83. At the dealership right now...advice pls.
  84. Rear Window problems
  85. 3rd gen tow hook bolts (frame rail) torque specs?
  86. just test drove 05 Tacoma
  87. Trailmaster steering shaft question
  88. Dim Headlights!
  89. Yummm! new Truck on the lot!
  90. Favorite Headlight shop?
  91. 22re Timing Chain in Pittsburgh, PA
  92. Rock Crawler Steelies Black Paint ?
  93. No light in glove box,cigarette lighter ring or ash tray
  94. Wheel Size and Functionality Question
  95. CEL that comes on and goes off by itself
  96. helllllp! fuel problem? need help!
  97. tires
  98. Considering selling 93 4x4 Near PERFECT, LOW MILES, Must See!!
  99. The 05 Tacoma is here….
  100. V6 Supercharger question
  101. how could it have affected the engine?
  102. California smog and camshafts
  103. Lowering my truck...?
  104. 1990 Cruise control help
  105. HELP! how hot does your transmission get?
  106. POLL?: Stock or Billet Grille?
  107. 3.4 swap question - need help asap please
  108. Seat Conversion 1994 extra cab 4X4
  109. 04 2.7 off roading
  110. Tight turns make my 87 4Runner have a POPing sound
  111. Lights IN TJM...Anyone ever done this????
  112. 94 3.0 V6 ticking/nock sound through RPM's
  113. SR5 fender flares??
  114. Where can I find an A/F guage....
  115. Roger Brown is the MAN!!!
  116. Help! How to take apart the corners?!
  117. Rear window lock siezed...fix?
  118. Lift kit or springs and shocks?
  119. 2nd gen shifter
  120. Links to pics of my 4runner stuff for sale
  121. gas guage doesnt work any more
  122. 2nd gen taillight grill guard (no drilling)?
  123. East Ky. Becomes Big Draw for Off-Roaders
  124. 3RD Gen Taurus Fan Install.
  125. Deckplate Open or Closed, General Guidelines???
  126. who replaces inner CV boots 4 cheap ijn the SF bay area ???
  127. Removing Heavy Duty Springs
  128. TRD LSD for the deep fluffy stuff
  129. drivers side low beam was out, not bulb
  130. Wiper Problems
  131. 3.slow dead??
  132. Help removing 80 amp fusible link
  133. Engine noise!!!!!! What could it be?
  134. Turned the BIG 3-0 (and some MUD pics)
  135. 03 Runner...rekeying ALL locks ???
  136. 235/75 R15 on a 7 inch rim?
  137. Anyone running 295/75/16 ?
  138. Best location for new oil sender (Autometer oil pressure gauge)
  139. dual filter relocation
  140. Are your kids addicted to wheeling?
  141. coupla action shots
  142. skid plate
  143. A/C Compressors
  144. two taco questions
  145. Help
  146. Is this bad?!?!
  147. confused on the rear bearing
  148. Hilift-poor man's cargo-area mount
  149. For The Trail: Taco or 4Runner
  150. WOOOHOOO! Got some Asin hubs!
  151. Window question
  152. Opinions on Performance springs/bilstein combo for 3rd gen
  153. Wanted; 2004 4Runner brochures
  154. Engine importers
  155. Poly Bushings
  156. TELEMUNDO! Who woulda thought?
  157. Lightforce 140's
  158. Timing belt alignment
  159. tranny noise
  160. Replacement digital clock?
  161. What size is the rear axel of the '97 4runner
  162. Is my master cylinder going out?
  163. HELP!! Anybody have a pioneer CDX-M30 changer?
  164. exhaust clips?
  165. Looking at a 1996 4Runner, Opinions Wanted
  166. Rear brake adjustment question
  167. new battery
  168. Finally did it right and got Yukon's
  169. Best Upgrade Route:
  170. DE-Chroming Questions...
  171. Gearing question
  172. Increased Idle on 3.0
  173. replacements for Cracked heads on 3.4 S/C'd
  174. Cheap 99-02 Factory Hella fog light color conversion
  175. Philips Vision Plus H1, H3, H4, H7
  176. Rear driveshaft question
  177. Does anyone know where to find.......
  178. 15x8 Or 15x10
  179. Should a clutch smell this bad?
  180. Making the mixture leaner...?
  181. 22re cracked timing cover!!!!
  182. hitch spare tire carrier
  183. Help..Spark plugs
  184. Alpha Accessories... are they reputable?
  185. need info on 88 4runner
  186. ahriman's rig w/bumper - [pics]
  187. Toyota FJ Cruiser Concept.... anything new?
  188. Rear Wheel Studs
  189. Just blew my 3rd rear end, It's time for a new housing...
  190. 3rd Gen LC rims on a 2nd gen 4Runner?
  191. Downey headers and body lift
  192. Anyone run 245/75/16's ?
  193. Which Shocks?
  194. Stant T-Stat
  195. I want a TJM.....
  196. OK I've narrowed it down to this....
  197. Time to upgrade the horns, any ideas???
  198. Help w/diagnosis
  199. Rough Idle cured
  200. bumper ready and coated
  201. 2005 Tacoma Pricing
  202. Exhaust differences?
  203. anybody up for an absurd favor or in Denver area headed to Utah?
  204. A few pictures from tonight. (Snow & Sunset)
  205. 04 Tacoma D-Cab, how much did you pay?
  206. Swapped Intake and Battery - Done
  207. New Custom Intake 22re
  208. Air lifts after Lift ??
  209. vibration in 4 wheel drive
  210. What does the computer do on a carbureted truck?
  211. Rough idle after knock sensor replacement
  212. ugly toyota green
  213. Quick Question - 3rd member
  214. Looking at a truck.
  215. 2nd gen clear tails on ebay now!
  216. bent idler arm
  217. tacoma fuel pressure?
  218. Custom front bumper w/LightForce 240's
  219. Feedback on Dunlops on 2004 Sport Editions.
  220. If the pressures sensors are removed from the wheels….
  221. Ball-Joint BOOT ONLY Part#????
  222. tail light relay?
  223. Intake question
  224. 89 22RE Engine Part Questions
  225. Will a 1991 22RE head work on........
  226. questions on 94 pickup.
  227. What tools do I need??
  228. Backspacing question
  229. Locked Water Pump?
  230. Spare tire (aftermarket wheels)
  231. this a good deal on a clutch?
  232. Towing advice needed
  233. Street mods
  234. Well I finally got some pics of my truck!!
  235. 4WD Light Problem..Any Ideas
  236. Watch a new Toyota being built here
  237. How do you???
  238. Addco Rear Sway Bar Bushings
  239. Custom Ski Racks for Tacos
  240. Found Clanking Noise...NOW WHAT???
  241. 99 3.4LV6 misfires
  242. 4runner engine swappers click here!!!!
  243. Fuel Guage Not Working
  244. Electrical Problem
  245. New intake and exhaust ?'s for a 99 3.4L 4Runner
  246. 3rd gen won't drop into overdrive...help!
  247. Rear spoiler/Wing
  248. Got a rattle and more rattle...need the silence...
  249. High Beam Switch ?
  250. Tranny Problem?
