changing light in headlight on 1st gen
Old Oct 21, 2004 | 05:20 PM
needayota's Avatar
hey all i need to change my bulb in my 1st gen, i took it out and it looked to be soldered to 3 little bent rods. so how do i go about putting one back it?
also before i took it out, i would turn on my lights and have to knock on that one to get it to come on. is that the wiring or the bulb itself?
thanks all
Old Oct 21, 2004 | 06:58 PM
85TurboRunner's Avatar
there shouldnt be anything soldered to your headlights, they should just unplug, im guessing somebody cut the plug off and soldered the wires directly to the tabs on the back of the light, right? if thats the case i'd be searching for a new plug at a junkyard or somthin.
Old Oct 21, 2004 | 07:35 PM
jimbo74's Avatar
also unless you have modified something, you should have sealed beam headlights.....
Old Oct 21, 2004 | 08:12 PM
superjoe83's Avatar
you have to change the whole thing, those type are a sealed unit and the bulb itself cant be replaced alone
Old Oct 21, 2004 | 10:03 PM
Tacoma Dude's Avatar
Ditto what Joe says.
Go to your local auto supply shop and browse through their Chilton's or Hayne's catalogs. The information you need will be in there.
Old Oct 22, 2004 | 04:18 AM
dajabr's Avatar
They're sealed. When I bought my truck it had the old school incandescent dim bulbs, simply upgrading to regular cheapo halogens was a huge improvement. $10 each.
Old Oct 22, 2004 | 04:25 AM
HondaTec521's Avatar
Part # H6054 is for large rectangular Halogen.If you upgrade do both sides.
Old Oct 22, 2004 | 03:47 PM
needayota's Avatar
so basically i need a whole new head light?
how much is that gonna run me?
i figured something was wrong with that, but i just figured eh its the 80's
Old Oct 22, 2004 | 03:51 PM
superjoe83's Avatar
it will probably run you about $10-$15
Old Oct 23, 2004 | 08:07 AM
needayota's Avatar
that part number is good at the dealership?
Old Oct 23, 2004 | 08:34 AM
4Crawler's Avatar
You can also upgrade the housings to an H4 halogen version Swap out the sealed beams for 6054/H4 housings and then you can just change the bulb in the future. And you get more light to boot.
Old Oct 24, 2004 | 04:18 PM
Mrs. Crash's Avatar
ah hah. Search method does wonders. I was just going to ask about the brighter headlights. Mine is out and I figure if I'm going to have to get a new one I might as well get brighter ones. Ok I found out I already have the upgraded hella lights and I just need to replace the bulbs. I'm looking for the upgraded lights. almost the blue/white bulbs I believe..???
smthwsn357
May 1, 2024 07:28 AM
ashersullivan88yota
Jan 18, 2022 05:37 PM
Jun 1, 2021 01:51 PM
coryc85
Jul 6, 2015 04:07 AM
HRDC0R19
Jul 5, 2015 06:43 PM
