drivers side low beam was out, not bulb
Old Oct 18, 2004 | 06:24 AM
mainer's Avatar
I have a 92 pick up and the drivers side low beam was out, so I replaced the bulb and it still didn’t work. High beam worked. I tested the new bulb with an ohms meter bulb is ok new and old one. Tested voltage at bulb, I finally figured out that the switch puts ground on the bulb to light it. There is no ground on the connector on low beam drivers side, there is on the passenger side. There is ground on high beam both sides. I tried to chase the wiring from the light to the steering column switch and it must chance colors somewhere.
Dose anyone have any idea where to trouble shot this wiring trouble? Can I run the low beam ground from the passenger side to the driver’s side?
Thanks
Old Oct 18, 2004 | 04:36 PM
yamarocket630's Avatar
Just run the wire straight to ground. The low beam filiments will stay on any time the headlamps are on, making your highbeams that much better (do this to both sides). As an added benefit, the low beams will be brighter, as the voltage loss from the connector back to a good ground is typically 1.5 - 20. volts, due to the small gauge wire and all the connections in the stock harness.
Old Oct 19, 2004 | 07:16 AM
mainer's Avatar
Thanks I'll try it. Sounds a lot better then trouble shooting a bad wire in the harness. Will there be any issues with the incressed load running both HI/LOW?
92 22RE
Kurt
Old Oct 19, 2004 | 02:15 PM
Shouldn't be a worry. The power comes from a relay in the underhood fuse block, so It's all good on that end, it's the ground side that sucks.
thefishguy77
Jul 30, 2015 10:59 AM
msane99
Jul 17, 2015 10:13 AM
razorman8669
Jul 12, 2015 12:13 PM
crashburnoveride
Jul 10, 2015 06:39 AM
MTLroadierunner
Jul 6, 2015 12:17 PM
