Gearing question
Old Oct 16, 2004 | 09:46 PM
Yamaha+Toyota=Fun's Avatar
Gearing question
Recently I have been looking into re-gearing my truck. From what I've heard the best gear ratio to run with 31s would be 4.11. Would it make any sense just to do the rear diff, or would that make 4wd all messed up? Also I am considering running 33s some time in the future, would these gears work ok for them too? Lastly what are a few good company that sell new gear sets?
~Austin
Old Oct 16, 2004 | 09:49 PM
rimpainter.com's Avatar
Yes, if you change the gear ratio in the rear diff on a 4WD without changing the front ratio, you will eventually ruin something expensive.
Old Oct 16, 2004 | 09:51 PM
Anyone that has done this, how difficult was it to do?
Old Oct 16, 2004 | 09:54 PM
You mean a front and rear complete diff (housing and all) swap? I have. If you mean gears, then I have not. I hear that is best left to the pros.
Old Oct 16, 2004 | 10:00 PM
This sounds like its gonna get expensive real fast
I was hoping to just change the ring and pinions, but thats probally not gonna happen for awhile!
Old Oct 16, 2004 | 10:01 PM
Well keep asking questions, you might be surprised. Someone else might chime in that is more familiar with gearing changes.
Old Oct 16, 2004 | 11:08 PM
toy283's Avatar
First off, with your truck, you already have 4.10 gears. With 31" tires, you want to go with 4.56's. Second, swapping ring and pinion gears really isn't that difficult once you have all the tools you need. Figure to spend $200 or so just on tools. For a one-time thing, it usually isn't worth it although there are other uses for the tools you'd need. Mostly, setting gears requires a lot of patience, you may have to do it several times in order to get them right and if they are set badly, they will have a very short life. This is what scares away most people from setting their own.
Old Oct 17, 2004 | 10:13 AM
Blackulua's Avatar
~Austin
Go with 4:88's.Its gonna give a lot of torque and acceleration on and off-road.Tire choices will be 31's to 33's.Look for a ring and pinion installer to do your gears.I bought my gears from Superior Gears for less than $600.
Old Oct 17, 2004 | 10:41 AM
My truck didn't come stock with 31s so im pretty sure that i dont have 4.11 gears. Anyone with 4.56 gears around what rpm are you turning at 60-65mph? I would like to stay at or below 3000 rpms. Thanks for your replies!!!
Old Oct 17, 2004 | 04:00 PM
Nathan Buchanan's Avatar
5 speed pickups came with 4.10s for 225/75 tires and 4.56s for 31s.
You have 4.10s unless someone put another ratio in there.
Old Oct 17, 2004 | 06:28 PM
Guess that shows how wrong a person can be! I think ill go with 4.56 then. Has anyone used NWOR gears, their shop is about 2 min away from my house!
Old Oct 17, 2004 | 06:31 PM
superjoe83's Avatar
i would go with a quality gearset, Yukon, US gear, precision, there may be a couple others, but what ever you do don't buy Genuine Gears, trust me on that one
Old Oct 17, 2004 | 06:34 PM
This is one thing I wont go the cheapo route on, I dont want any exploding diffs!!
Old Oct 17, 2004 | 07:28 PM
kyle_22r's Avatar
do a search on some forums on NWOR. bad news wherever you look
Old Nov 13, 2004 | 09:17 PM
Ive thought about this for a month or so and I was wondering if it would be possible to find a 4runner or truck with stock 31s or and auto and take 4.56 or 4.88 thirds and put them in my truck. Is the possible, I have heard the factory 4.88 thirds are different than 4.56 or 4.10.
Old Nov 13, 2004 | 09:23 PM
toy283's Avatar
Yes, they are different but they will bolt up to your axle housing no problem. The problem with these thirds is that you are stuck with the ratio. The factory 4.88 ratio gears are different (more pnion offset) than regular gears. As such there are no other ratios available that will fit. If you want a different ratio later on, you will need to find different third members and go from there.
Old Nov 13, 2004 | 09:46 PM
Sweet, I dont think I will go any larger 4.88 and I do I could always just use my old 3rd. How hard are these 4.88 thirds to find? Also how hard is the install?
Old Nov 13, 2004 | 10:19 PM
Glenn's Avatar
I'm pretty sure that you do have 4.10's.
I have 31's, 22RE, 5-speed, and 4.56 gears. 60-65 mph turns the motor about 2500-2750 RPM.
XtraCab
Apr 12, 2020 05:25 AM
oldirtydirt
Feb 23, 2020 09:30 AM
mskalmus
May 28, 2017 07:51 AM
coffey50
Jul 28, 2015 10:55 AM
Jnkml
Jul 6, 2015 01:20 PM
