HELP! how hot does your transmission get?
Old Oct 18, 2004 | 06:13 PM
gtfourdreams's Avatar
im just wondering, how hot does your transmissions get? driving from Mpls to Mankato, almost 100miles doing about 70 all the way there, my transmission stick gets pretty hot. its still touchable, but definitly around 90 degrees. is that normal?
btw, i just put in new Redline 70w90 trans oil in the trans and in the gearbox itself. my 4runner is an 89 with 187,000 miles, V6 4WD.
Old Oct 18, 2004 | 06:33 PM
rimpainter.com's Avatar
You are gauging the temp of your transmission by touching it?
Old Oct 18, 2004 | 06:38 PM
i donno. ive never had a truck before! but the transmission shifter is pretty hot on long drives. i dont get any lights on the dash, but i was just curious if it should be that warm.
Old Oct 18, 2004 | 06:40 PM
Oh, the shifter. I thought you meant you crawl under and feel the bellhousing
If you are worried about it, pull the fill plug and check for excessive shavings (if it is a 5 speed) and smell the fluid.
Old Oct 18, 2004 | 08:47 PM
Erich_870's Avatar
I noticed mine got pretty hot last winter before my rebuild, it was getting hot in the snow! That freaked me out, its below freezing and my shifter handle is HOT! We'll see how the new, quite, smooth trany is this winter
Erich
Old Oct 18, 2004 | 09:19 PM
superjoe83's Avatar
its normal to see 200 degree fluid temp in a gearbox or rearend
Old Oct 18, 2004 | 09:40 PM
Erich_870's Avatar
Thats good to hear, my transfer box gets warmer than my tranny still.
Has anyone put a tranny or transfer box temp guage in? I'm a freak for data
Erich
Old Oct 19, 2004 | 05:28 PM
hmm.. ok. well, i put in Redline 70w90 in both tranny and transfer.
also, we do have a light on the dash that warns if the transfercase/tranny overheats, correct? i cant tell.
Old Oct 20, 2004 | 03:05 PM
Gabe's Avatar
Mine will get pretty hot to the touch, especially when towing uphill, but thats just the way it is.
shrek99352
Aug 31, 2015 04:16 AM
Gio8
Aug 27, 2015 12:14 PM
Dennisx2
Aug 10, 2015 06:48 AM
Dennisx2
Aug 4, 2015 01:26 PM
Poncho0206
Jul 10, 2015 06:21 PM
