What tools do I need??
Old Oct 15, 2004 | 06:18 AM
tarheelrunner's Avatar
I am trying to get everything together so that I can install the 3" Revtek kit on my 2000 4runner. I was trying to make a list of everything I would need for the install, and I was just going to see what you guys recommend. What tools do I really need, what tools will make the install a lot easier, etc. Thanks for the help.
Old Oct 15, 2004 | 06:24 AM
rimpainter.com's Avatar
Air tools. I just got a really nice complete set up (air ratchet, impact gun, hose, compressor, air attachments) for $400, brand new. I can't believe I turned wrenches this long without air tools. The decrease in install time is unbelievable. If you can swing it, let me know and I will give you a list of everything I purchased.
Old Oct 15, 2004 | 06:26 AM
Yeah I'm sure that air tools do make the install a lot quicker. I've got a few friends with air tools so I should be able to borrow them for the day. Which air tools do you use on the install?
Old Oct 15, 2004 | 06:29 AM
MTL_4runner's Avatar
I use an air ratchet, impact gun and cutoff wheel on a regular basis.
Air drill and angle grinder are nice to have as well.
Old Oct 15, 2004 | 06:33 AM
I'll show my ignorance on the subject--> what is an impact gun?
Old Oct 15, 2004 | 07:10 AM
It's big and heavy and generally used for high TQ applications (wheels, crank pulley bolts, axle nuts). Mine is rated at 275 at max press. $50 at Home Depot.
Old Oct 15, 2004 | 07:21 AM
TDiddy's Avatar
Christian, what brand compressor did you end up with? I have some gift cards to burn at the Depot...
Old Oct 15, 2004 | 07:26 AM
Tom-
I actually went with the Coleman compressor at Costco. For the specs and price, it can't be beat. Oil free, 155psi max press, 28 gallon capacity, etc. $250 at Costco. I then went with $120 worth of air tools and accessories from HD.
I find myself looking for reason's to fire up the air and rev the air ratchet...kinda dorky but oh well.
Old Oct 15, 2004 | 07:30 AM
TDiddy's Avatar
Ohh, OK. Costco opens here in December, I can probably wait.
Old Oct 15, 2004 | 07:44 AM
Very, very useful tool....get's off even the most stubborn rusty stuff you can imagine!
.....or it snaps it off.
Old Oct 15, 2004 | 08:06 AM
Leave it to Jamie to post the cheapest gun available...
Old Oct 15, 2004 | 08:33 AM
Awwwww, c'mon....they only cost a kidney or two.
....after being a mechanic I got spoiled on snap-on stuff.
Old Oct 15, 2004 | 08:39 AM
Biff's Avatar
Not dorky at all. I do the same thing with my air tools, my wife thinks I'm crazy.
Old Oct 15, 2004 | 03:27 PM
Tacoma Dude's Avatar
If you don't go for the pneumatic tools make sure you have a torque wrench or some long handled socket wrench - it'll make the use of the coil compressor easier.
You'll need the appropriate metric tools. Good writeup - and maybe even a bottle jack to get that A-arm down. I found a small prybar was helpful in getting the shock oriented correctly if I messed up when releasing the compressor.
Don't forget a good set of jackstands, wheel chocks, and whatever miscellaneous stuff too.
jb451
7
Oct 7, 2022 06:58 AM
RobotMoose
Feb 22, 2020 07:44 AM
Scottcrb
Mar 3, 2016 11:57 AM
fabing455
Sep 7, 2015 08:08 AM
