36 mm Ø nut in front axle
Old Oct 21, 2004 | 04:59 AM
KZN185W's Avatar
Hi,
I just had the outer CV boots replaced in my Surf and I'd like to know if I need to use loctite on the 36mm Ø nut.
Is the cotter pin on the nut good enough to keep the nut in place? Did Toyota use loctite on it when it came from the factory?
Thanks for any info.
Old Oct 21, 2004 | 06:19 AM
loosehead's Avatar
Roy-
I replaced an axle on mine a while back and saw no signs of thread lock compound. With the nut torqued to spec and the cotter pin, it should be just fine.
Old Oct 21, 2004 | 08:44 AM
Good Times's Avatar
like what loosehead said, if you torque the 36mm down and use the cotter pin to secure it, you should be fine.
Old Oct 22, 2004 | 03:57 PM
KZN185W's Avatar
Thanks a lot for the info guys!!
Old Nov 13, 2004 | 07:21 PM
KZN185W's Avatar
Originally Posted by loosehead
...With the nut torqued to spec and the cotter pin, it should be just fine.
Jayson,
Would you happen to know the specified torque for the 36 mm Ø nut? I would like to have the torque on mine checked, just to be sure.
Thanks again.
Old Nov 13, 2004 | 08:07 PM
Dirty White Boy's Avatar
Guest
Originally Posted by RoySharif
Jayson,
Thanks again.
Roy,
Sorry to highjack, but, would you happen to have any pics of your rig? I totally dig the out-of-the-states rigs. Something about them being different.
Old Nov 14, 2004 | 12:00 AM
KZN185W's Avatar
Originally Posted by Dirty White Boy
Roy,
Hi there!
I'll be posting pics of my truck soon..in this forum.
Old Nov 14, 2004 | 07:20 AM
88FJ62-Cruiser's Avatar
235 Newton meters of torque
you out of towners like newton meters right?
Old Nov 14, 2004 | 02:23 PM
KZN185W's Avatar
Hey,
Thanks a lot!! I appreciate it. And yes, we prefer N-m of torque since we're used to SI units. When I was in high school, we used to have the FPS (English) units but was later on shifted to SI.
BTW, where can I get hold of a copy of the service manual for a 3rd gen? I presume that the pic you attached is from the FSM. Isn't it?
Thanks again.
88sasturbotoy
Jan 30, 2026 01:57 PM
oldirtydirt
Feb 23, 2020 09:30 AM
jerusry
Oct 19, 2015 05:28 PM
deepmarsh
Aug 6, 2015 03:44 AM
PlayAwhile
Jul 20, 2015 11:36 AM
