Removing Heavy Duty Springs
Old Oct 18, 2004 | 06:43 AM
gpwhite7's Avatar
Can someone tell me how to remove the Heavy Duty Springs on the back of my truck?
Thanks
Old Oct 18, 2004 | 07:30 AM
mt_goat's Avatar
Thanks
Do you have leaf springs? Year, model?
Old Oct 18, 2004 | 12:05 PM
gpwhite7's Avatar
Yep, there are leaf springs and an additional heavy duty spring over the shocks. It's a 1991 2WD Standard Bed Toyota Pickup
Thanks
Old Oct 18, 2004 | 12:26 PM
mt_goat's Avatar
Thanks
What? Leaf springs AND coil over? I've never seen that, but here are some good instructions on leaf springs
http://www.4crawler.com/Diesel/Cheap...l#Add-a-leaves
http://www.4crawler.com/4x4/4R_suspension-III.shtml
Old Oct 18, 2004 | 02:27 PM
anthony1's Avatar
I thnk Monroe shocks makes these coil springs that slips over the shocks....is that what you're talking about?
if yes then just remove the shocks.
Old Oct 18, 2004 | 02:43 PM
gpwhite7's Avatar
Yeah, these look like they slip over the shocks. But I'm wondering if when I unmount the shocks are they going to extend and be hard to put back on after I pull the coil spring off of them? Do you jack up the rear axle or bumper? Thanks
Old Oct 19, 2004 | 05:27 AM
mt_goat's Avatar
I don't know anything about those shocks, but what I did to remove and add leaves to the spring pack was jack up the rear axle and put jack stands under the frame such that the wheels were slightly off the ground with the jack removed from under the axle. Here are some pics of the process I went through to add 2 leaves. http://community.webshots.com/album/191135149WHNAHa
Old Oct 19, 2004 | 09:54 AM
gpwhite7's Avatar
The guy I bought this truck from added the heavy duty coils over the rear shocks so he could load it with wood. But I don't haul anything like that and the truck bounces like crazy because of it. It also has the leaf springs you were talking about.
I saw your webshots album, that was good!
nvdesertrunner
May 11, 2020 08:18 PM
Luvmeye22re
Aug 4, 2015 03:53 PM
defrag4
Jul 31, 2015 10:50 AM
msane99
Jul 17, 2015 10:13 AM
Nickdigg
Jul 7, 2015 06:04 AM
