Rear brake adjustment question
Old Oct 17, 2004 | 09:06 AM
obxfishn's Avatar
I was trying to take my right rear hub off to check the brake shoes and I turned the brake adjuster the wrong way causing the brakes to grasp the hub and I am unable to turn it back the other way because its meeting some resistance :pat: . Any ideas or thoughts on how to correct this issue.
Old Oct 17, 2004 | 09:33 AM
WATRD's Avatar
A couple of thoughts;
You mean you were trying to take your "drum" off, right?
You shouldn't have to back the shoes off to remove the drum.
Odds are good you aren't strong enough to get it *really* stuck, so just go drive it a bit with the shoe dragging and it will quickly wear to the point where you can once again get the drum off.
Old Oct 17, 2004 | 09:51 AM
Sludge's Avatar
there is a level thats on the adjuster that you need to push back with a screwdriver so you can turn the adjuster knob the other direction.
Old Oct 17, 2004 | 09:55 AM
obxfishn's Avatar
When you say push the leveler back, which way are you talking about?
Old Oct 17, 2004 | 10:16 AM
Yoda's Avatar
There is a LEVER inside the brake housing to prevent the brakes from backing off. If you push in on that lever with a piece of coat hanger wire or a small screwdriver, you should be able to back off the adjuster.
Old Oct 17, 2004 | 10:17 AM
Sludge's Avatar
when you are look in the hole of the adjuster you will be pushing the level back or away from you.
Old Oct 17, 2004 | 10:25 AM
obxfishn's Avatar
OK- I'll try it and post my results later on this evening. Thank you all for your help.
Old Oct 17, 2004 | 04:49 PM
obxfishn's Avatar
PROBLEM RESOLVED- Thank you all for your help. Leave it to Yota Tech and its members to help out.
Jun 1, 2021 01:51 PM
TURBOrunnerNM
Jul 22, 2015 11:01 AM
icentropy
Jul 9, 2015 02:12 PM
Cplmike
Jul 8, 2015 08:47 PM
MTLroadierunner
Jul 6, 2015 12:17 PM
