Won't start. Need help
Old Oct 19, 2004 | 12:14 PM
paulmcb's Avatar
97 4Runner ltd. When I turn the key, all i get is a click. Warning lights do light up. After a few tries, it will start, but doors won't lock automatically either. I've found if I hit gas pedal while cranking it, it starts on 1st try. The check engine light was on over a week ago. It went off after an hour or so. Don't know if related.. Any suggestions???
Old Oct 19, 2004 | 12:24 PM
Battery in good shape? If it's original or old you could just need a new one.
Old Mar 17, 2005 | 03:15 PM
ETPatt's Avatar
I had the same problem in mine. It took a few turns to get it to start up. All I was hearing was a click. Weird thing was is that it was messing with my door locks. Another problem I was encountering was sometimes when I tried to turn off the 4runner the starter kept cranking but the engine shut off. I had the starter replaced and have had no problems with that since.
Old Mar 17, 2005 | 03:50 PM
MTL_4runner's Avatar
You might want to have that OBD code pulled, it will be stored in the ECU memory and might be related to the starting problems.
Old Mar 18, 2005 | 06:36 PM
wrenchmonster's Avatar
Check your battery, and check the starter. Also do a volt drop on your cables. Sounds like a battery from your initial description. Weak batteries do WEIRD things, so I wouldn't dwell too much on the door lock problem for now. Also, check out your ignition switch. Hope this helps.
-Wrench
JonG85
Jan 18, 2023 04:31 PM
JookUpVandetti
Sep 30, 2015 08:58 AM
voiddweller
Sep 28, 2015 11:21 PM
Robert-b83
Sep 28, 2015 12:21 PM
Armstrong486
Sep 19, 2015 12:37 AM
