- Accident aftermath - advice please
- PLEASE HELP, 4x4 trouble....
- Rub/Moan/Squeak from front end of 4Runner (Please Help!)
- Am I asking too much? Need an opinion.
- Rear diff--Install Kit?
- bigger cam = ˟˟˟˟˟ty milage
- what size jumpstarter to get?
- curbing damages?
- O2 sensor agian
- Distributor curve tuning on 22r/re??
- Plugged breather
- New 18" wheels
- Wet Okole Tan Color Match
- 92 truck speedometer not working...
- wheres the MAF on the 22re
- crap! crap! crap!
- Jack size???
- HELP!!! Replacing windshield wipers!!
- rear ABS light on after body lift :eek:
- Installed my 3" rb 2nd gen body lift this weekend. (b4 and after pics)
- 1995 4 runner coolant leak help needed
- Another header question?
- 2000 Tacoma cat.converter???
- Need new mirrors
- HELP! Security Light
- Spotlights
- New Toyota
- Relay / Switch Question
- PCV frozen, 3.4L spewing oil everywhere... Anyone else?
- Rav4 brake bleeding
- Running cool.
- Tire decisions with coil lift
- backed into my sister's house today
- what is this?
- auto to manual swap on 3rd gen
- I found clear tails for 2nd Gen 4Runners...
- Help with new front bumper
- Synthetic oil switch
- Starter Removal TRICK!
- 1st Gen Lower Valence...
- changing the pinion flange
- What is it!?
- 1st Gen Bumper Aux Lights?
- Remote Starter on a 1st Gen?
- where is the cheapest place for....
- Terrible noise coming from my S/C 3.4, HELP!
- 99 4runner engine immobilizer
- Lambo doors?lol check it out...
- Newbie Questions on buying 3rd Gen
- I dunno what I was thinkin
- !@##$ old lady!!
- Modded a vac line from intake to airbox
- Tundra/OME front lift problems, many!
- Need help with a Bad squell (sp?)
- finally, some progress
- Viper vs. Clifford remote start and alarm systems?
- how long are you guys going on oil changes??
- generation explaination
- Part Numbers?
- 2nd gen body lift: steering shaft
- 1994 4X4..What grease to use on rotor assembly
- scs aftermarket cruise control won't work
- Remote Start Completed....
- Electric cooling fan modification tips needed
- What's this wire grid for anyway ?
- "Oversized" Oil Filter?
- very weird rig
- Rear wheel locking up
- 4.5" lift and 315/75R-16??
- CIL light goes out after filling up gas tank. WTF??
- Any Trick to removing PVC
- Is it bad to....
- Bilstein 5100's? Help
- Replacing calipers help..94 4runner
- CV boot kit - which grease to use?
- 4Runner Computer Chips ????
- 285's and 1" BL???
- '95 2x really starting to sag in the rear...
- Ebay use question, please help with this one.
- noisy rear hatch
- Flowmaster 40 series?
- Need help finding fuel lines under hood
- Umm...yea, Hella 500s wont turn on...
- which hose is this?
- abs light
- Aftermarket Radiator Hoses
- ARB installed-Finally
- 15 min. wheel trim mod
- jeep guy needs some TACO help!!!
- stainless steel brake lines
- Hood scoop for the tacoma?
- Highlander WEAPON R intake?
- Help me with my "click, click" sound??
- Idle Screw 95 Taco
- Charging/electrical problem.
- price to paint body parts
- 22re leaning out?
- Carburetor rebuild?
- 2nd Gen Cruise Control
- Leaking Rear Differential
- Bilstein 5100 vs OME N85/N94 for Taco rear
- Dust in through ventilation- How to keep it out?
- Stock or aftermarket muffler ?
- Gas gauge broke
- looking for 99 sr5 parts
- Not real happy! would like some help!
- home for the holidays--snowy trails in OH?
- aftermarket carbs?
- running board compatibility (97 LTD on 00 SR5)
- Power Antenna
- The UPS guy made my day!
- 94 pickup w/22re motor
- V8 4 Runner swap
- Idle Problems
- Claiming Wheeling whoopsies on insurance
- Leaking transfer case at driveshaft?
- $3000 to replace the head gasket
- MORE FACTORY LIMITED SLIP DIFF, MADNESS AND I.D....tag location?
- Headers
- Diesel Question/Opinion
- my ((brake)) like wont go out. :(
- Bazooka BTA10200 sub
- swap or no swap
- Why should I buy a bigger tire? / Winter tires all year round?
- Brush Guard question
- 2005 Tacoma, WTF is this all about???????????
- This should have been a 4Runner commercial!
- GX470 wheels/ hello from new member..
- Daystar Lift Kit?--Any Good?
- I Got the Scoop (*PICS*)
- WTB running boards for 3rd gen
- '99 Front Brake Job
- 2nd/3rd/4th GEN 0-60, 1/4 mile, braking, etc. compilation
- Wheel Selection?
- window
- My Balls Are Gone!!! :(
- Air intake tube HELP!
- Back Seat Compartment Dimensions
- Had some Mod Q's about my first Toyota
- 95 Tacoma throttle problem
- To index or not to index...
- Possible to unlock yota with clothes hanger?
- Another A/T temp light thread
- UPDATE: 2001 Runner PASSED inspection
- steering wheel squeak when turning=annoying
- cluster lights
- picked up my new 05 Sport V8
- Anyone driven a 2005 Tacoma 4 cyl yet?
- brush guard oppinions?
- How do you guys mount your cellphones?
- 22r heddman header
- squeaking belts...
- I smell a ...
- lifting 01 4runner
- What was supposed to turn into a wonderful day of picture taking..(pics inside)..
- Fluid comming from front shock.
- 22re question
- Limited Slip Toyota Diff, How Accurate Is The Door Jamb Sticker???
- Clock and Rear Power window share the same harness????
- LC Engineering?
- What's a good all around tire for these conditions?
- Cold Heat
- Help
- Fuel Release valve.
- Ok so I flushed my cooling system, but...
- Antenna Mast Install
- In need of a service tech page (Air/Fuel Sensor 01 4-runner)
- need final opinion on tires KM or KO
- 2gen 4runner screeching grinding noise right turns only
- Noob question for those with manual hubs...
- flat towing an 85 runner?
- Whining sound from engine
- Had a Remote Starter Installed - Long Story
- When cold, the engine gets a boost around 3000rpm..22re Strange ?
- Icelandic Toy Tacoma 2003 on 38"
- Oversize throttle body
- Speedometer gear damage??
- Optima battery life
- Newly intalled tranny seems to bog???
- flywheel installation ?
- Muth Mirror Systems for 2000 4runner
- Removing rear side windows w/o breaking glass???
- what does it take to have cold air?
- woo snow 4wheelin today
- This Is Ridiculous
- Door Panels?
- R&P Info
- Donkey Knocker question.....
- Looking for dyno chart for 4.0 V6 (4Runner/new Taco) and more q's
- I hate ICE!!! Slid into a ditch last night....
- Ceramic versus chrome headers?
- Maybe something easier...
- 98 Runner Oem/hella Fog Light Problem
- Painting PP Springs...Ideas?
- CV's and diff.
- Battery/Alternator Question
- Taco "clunk" after breaking
- Need some engine problem help!
- Where's that gasoline smell coming from?!?
- Please help, 4wd problem
- homemade winch mount pics.....anyone have any?
- Newbies First Runner (Pics)
- Fuel filter
- stupid stuff we have have all done
- 2002 S/C'd 4Runner idle problem
- flowmaster 40 went on yesterday
- A wee bit of dirt in the gear oil...
- 3.0 Headers Question
- Seatbelt wire
- to go check it out or not?
- Block heater and Power Inverter idea
- O2 Sensor Location?
- EBAY: AISIN hubs IFS
- Headlight dim on one side... 3rd gen
- Tailights
- high centered tonight...
- Brake Help PLEASE. This one is wierd
- Flange yoke leak????
- Tires make a difference....
- 95 3.0 EGR problem
- Lets say a guy hasn't changed his oil in a while...
- JDM engines???
- 5 spd Third Gens-Towing Questions-3,000 Plus Pounds
- Anyone have a Lift-Mate?
- A Few Questions Here
- I want to Buy this.....will it fit?
- Problem with Split Second FTC???
- Help! Newbie here
- smittybilt tube bumpers w/3"bodylift questions
- my truck is being funny
- APEXi SAFII install on a '2000, 3.4L Runner
- Squealing while only driving?!?
- Middle East front end?
- Sorry to ask.....
- How does a lifted 3rd gen 4Runner do on roadtrips?
- Toy 22RE engine whistling noise
- Seafoam
- Who has done the "BIG 3" wire upgrade?
- Hood Scoop ??
- Looking for a new project Toy
- introducing myself & have questions about tire size.
- need 2nd gen fuel tank
- Possible blown headgasket on my 94 yote pickup?
- 4 runner performance chips
- check eng. light ?
- Where are all the TRD decals???
- 1st Gen 4Runner Seat Swap
- Rims and 33x12.50R15 Pro comp tires for sale**(PICS)**
- Rear brakes R&R how to needed. frnt brakes replaced 2X.
- 1996 exhaust gutted.
