V8 4 Runner swap
Old Dec 22, 2004 | 03:20 PM
Bigblock's Avatar
V8 4 Runner swap
Has anyone tried to put a 5.2 Magnum in a 1992 4 Runner? Will it actually fit with no body lift?
Old Dec 22, 2004 | 04:24 PM
kevin444's Avatar
For a moment i thought this was about dropping a i-force v8 toy engine into there.. good lawdy..
Old Dec 22, 2004 | 04:35 PM
HOJU's Avatar
I'd love to see someone drop in the I-Force into a 2nd gen, or better yet a 3rd gen!
Isn't the magnum a 360? either way i'm sure it could be done, just more expensive than a chevy or ford swap (more custom pieces that would have to be made)
Old Dec 22, 2004 | 06:36 PM
Hey said 5.2 which is a 318. 5.9 is the 360
Old Dec 22, 2004 | 06:40 PM
Cebby's Avatar
I think I've read that the i-force motor is too wide to fit either the 2nd OR 3rd Gen. The hot swap would be the 4.0 out of the LS400.
Old Dec 22, 2004 | 07:02 PM
kaneman23's Avatar
Why would you pollute a perfectly good Toyota with a hunk of ˟˟˟˟˟ motor? At least swap in an I-Force or something more reputable such as a Ford 302 or a small block Chevy (LS1)...
Old Dec 22, 2004 | 07:07 PM
HOJU's Avatar
that's right, i couldn't remember which it was....
the lexus V8 would be sweet, 300hp
Old Dec 22, 2004 | 07:20 PM
kevin444's Avatar
Take that porsche cayenne and bmv x5!
Old Dec 22, 2004 | 08:34 PM
Keggo's Avatar
True true...
Old Dec 22, 2004 | 08:59 PM
desert whomper's Avatar
why would u take the porshe, the new v8 runner that is supercharged is the fastest production SUV and it is a toyota, what else could u want?
Old Dec 22, 2004 | 09:07 PM
fiveofeen's Avatar
are you sure its the fastest prod suv? remember the GMC typhoon those run 13's stock as do the cayanne S
Old Dec 22, 2004 | 11:22 PM
jimbo74's Avatar
no, no...they are saying that the toyota would be able to take as in kick the snot out of the bmw or porshe
Old Dec 23, 2004 | 06:24 AM
Johnboy's Avatar
I tried to race a porshe in my 2nd gen the other day... We were both at a light and when it turned green I gunned it (or I tried) but i beat him to the next light. (probly cause he didnt realize I was racing) But then the next light, he let me go a couple of feet or so then he was gone... i felt like a dip˟˟˟˟.
Old Dec 23, 2004 | 06:58 AM
Cebby's Avatar
Sorry for the OT, but what is "Early Learing Software"? (in your sig)
Old Dec 23, 2004 | 10:27 AM
Phisherman's Avatar
The LS uses the A340E trans, makes life much easier.
Old Dec 23, 2004 | 03:46 PM
Bigblock's Avatar
I would put a 302 in there, IF I wanted to work on it every day. Besides that, I'll use what I already have.
Old Dec 28, 2004 | 06:14 PM
Bigblock's Avatar
pics coming when ball gets rolling.pretty big engine hole with no 3vze and tranny.
Old Dec 28, 2004 | 06:17 PM
Bigblock's Avatar
how much V8 torqe can yoty 8" rear end handle?
Old Dec 29, 2004 | 10:08 AM
Flamedx4's Avatar
The engine should physically fit in there, although a bit of body lift might make life easier. I'd be curious to hear if the shaft for the trans is right, because I *think* the bellhousing bolt pattern is the same. If not, the bellhousing from a jeep or the donor Dodge might work.
The rear end can handle the power just fine. The front is questionable though, if you thrash it a lot you might break something up front.
Old Dec 29, 2004 | 06:11 PM
rockota's Avatar
I saw a 318 in a 1st gen toyota 5 years ago in at the Back Hills Cruiser Classic. Fit pretty well... sort of.
Does the Magnum have a rear-mount distributor? Is a small-body available for it? If so, you might be able to get by w/o a body lift, but you'd have to mount the engine low and try to push it back as far as you can for radiator clearance.
As for the i-Force - rumors are that there are two 4.7-into-Taco's floating around... Trying to convince the guy who mentioned it to drive 300 miles to get pics.
