V8 4 Runner swap
Old Jan 30, 2005 | 10:11 AM
  #61
Bigblock's Avatar
well,the stock exhaust logs clear,oil pan clears,front driveshaft clears,everything is good.Starter,on the other hand,will not clear.Does anybody know of a starter mfg that could sell or make me one?
Old Jan 30, 2005 | 01:01 PM
  #62
3car's Avatar
http://cgi.ebay.com/ebaymotors/ws/eB...spagename=WDVW
what does it hit, and how bad is the interference?
Old Jan 30, 2005 | 01:24 PM
  #63
Gangus2006's Avatar
Someone should drop a modded 2JZ-GTE into their 4Runner...
Old Jan 30, 2005 | 04:46 PM
  #64
Bigblock's Avatar
starter hits the upper control arm where the torsion bar bolts on. as far as interference, about 3/4 or 1 inch. if i could find a starter angled another direction, besides straight out, it would work.
Old Feb 6, 2005 | 04:11 PM
  #65
Bigblock's Avatar
yall dont give up on me.i found a starter thats adjustable,if i could come up with some dough!
Old Apr 1, 2005 | 06:34 AM
  #66
cimahar's Avatar
Anything that goes in a Toyota should be Toyota, I looking into the 7M-GTE
230hp with a little head work and more air intake you might approach 300hp
for arounf $1500.00 and a little time, then IT'S STILL ALL TOYOTA, I would rather walk then drive a HeeP
Old Apr 1, 2005 | 09:31 AM
  #67
Skyline's Avatar
The 2JZ that several people mentioned would definately be a cool swap. But much less costly and just fine if you want about 300hp would be the strait turbo six from the JDM-only Toyota Chaser. Basically the same as the 2JZ but with a single turbo...so a lot simpler. In stock form, either of these sixes are capable of similar horsepower and torque to a small block domestic V8, and much lighter and infinetly more refined. You have virtually unlimited upside power potential if you want to mod the motor, and probably 50% additional power can be added on stock internals. Not to mention you'd be maintaining a Toyota drivetrain.
Old Apr 1, 2005 | 10:36 AM
  #68
DudeBud's Avatar
Originally Posted by 3yotys
I would put a 302 in there, IF I wanted to work on it every day. Besides that, I'll use what I already have.
funny only time i ever work on mine is when i change the oil or do a tune up
Old Apr 1, 2005 | 11:46 AM
  #69
Randomness's Avatar
Old Apr 2, 2005 | 04:28 PM
  #70
I SECOND THAT!!!
I have had only one problem(a busted valve spring) with the motor, and that's probably cause the guy who put my motor together most likely got all his parts from the junkyard. Which is where I found a replacement spring for 75 cents. I love my 302.
Old Apr 2, 2005 | 05:16 PM
  #71
kyle_22r's Avatar
i love ford vs chevy arguments. if you strip it down and rebuild it with quality components, you shouldn't have any problems.
now, there are some engines that are just plain bad(like the olds 403) but neither a typical ford or chevy smallblock has those kind of problems.
Old Apr 3, 2005 | 06:02 PM
  #72
Bigblock's Avatar
i think i'll just put my trusty 3VZE back in!
Old Jun 29, 2008 | 03:45 PM
  #73
chevota88's Avatar
this swap makes no sense.
Old Jun 29, 2008 | 03:52 PM
  #74
Belize Off Road Team's Avatar
a 4.7L would fit in a 2nd gen. I considerd it when i was making money, but i didnt have the resources at the time, other wise i would have.
Old Jun 29, 2008 | 03:57 PM
  #75
yotasavg's Avatar
soooo old!!!
Old Jun 30, 2008 | 02:37 PM
  #76
TexanTaco's Avatar
I know right! Ok I'm hooked now, I wonder if the swap went ok.
Old Aug 29, 2008 | 02:41 PM
  #77
Bigblock's Avatar
I said %#$@ it,and put a 3.4 in it.
Bigblock
Goddamnboh
3.4 Swaps
12
May 11, 2016 09:22 PM
vasinvictor
Jan 20, 2016 12:39 PM
DjShiznit
Jul 5, 2015 11:51 PM
TheManOutside
Jun 18, 2015 03:32 PM
infinityisfive
Jun 16, 2015 06:51 PM
