Air intake tube HELP!
Old Dec 21, 2004 | 08:34 PM
NathanBERG's Avatar
Unhappy Air intake tube HELP!
Okay need some help. I was changing my spark plugs and needed to remove the Air intake tube form the Fuel injection unit, and thats when I noticed that the Tube has a chunk in it and is letting air in, Big time! UMMM? Maybe this is why the check engine light is on, and it has been running strange???
Well anyway, Any ideas where I may find this part or how I might make one that works? It has the Crank case vent pipe on it, otherwise I would just find a pipe. Please help me!
Vehicle is a 1990 4runner V6..
Old Dec 21, 2004 | 08:38 PM
dwh91102's Avatar
go to the tech section here, shows you how to have one made at a local muffler shop, thats what i used and it works great
Old Dec 21, 2004 | 09:02 PM
TACOMANATOR's Avatar
Duct tape.
Old Dec 22, 2004 | 01:47 PM
NathanBERG's Avatar
Angry
:pat: Well thanks for the help. I spent the day looking for that darn pipe in wrecking yards and no luck.
I did not want to modify or use duck tape, So I went to the stealership and got raped!
That darn thing cost me $86.00 and tax. Over 90.00 big ones.
Well thats that !
Old Dec 22, 2004 | 06:52 PM
Marc P's Avatar
I have a tube that I used for my intake I will sell you. It is from a new Ford diesel and has worked great for me. All you will need it the rubber boots to connect it to the throttle body and maf sensor. I will even install the brass hose adapters for you. Here is a pic of how mine looks finished--
Installed
Old Jul 1, 2018 | 12:29 PM
Nate Allan's Avatar
Here is an aftermarket replacement
If I am understanding the part you need correctly, here is a part number from Doorman for a direct drop in replacement you should be able to get this at your local parts store, don't know if you still need it, but other people might.....
https://www.dormanproducts.com/gsearch.aspx?type=keyword&origin=keyword&q=696-703
Blamalam
Mar 12, 2022 07:34 AM
rusty904
Mar 27, 2017 05:20 PM
justdifferentials
Just Differentials
Sep 17, 2015 06:14 PM
Tacoma1313
Aug 17, 2015 05:44 PM
priest16
15
Aug 6, 2015 07:43 AM
