curbing damages?
Old Dec 26, 2004 | 10:43 PM
04Tacoma4x4's Avatar
curbing damages?
so as many of you know a snow storm struck the south today and tonight me and a buddy of mine were out in our tacomas and went to a huge parking lot where we started doing donuts. The back corner in particular was nothing but ice and my friend started doing 4 wheel drive donuts, but when i was doing regular donuts i could not stop and slammed into the curb pretty hard, they said that they heard something pop and that my passenger side came off the ground, my driver side hit the curb parallel. i then tried to stay away from the curb trying not to let it ruin my night, and ended up hitting it again but not as hard, this happened 3 times to me and 1 time to my buddy. what if anything could i have broken?
Old Dec 26, 2004 | 10:48 PM
turboale's Avatar
This sucks... you flat landers have snow and we have nothing up in the mtns!! You hit the same curb THREE times? Did you slide into it sideways? I don't completely understand... Is there any wobble or vibrations?
Old Dec 26, 2004 | 11:07 PM
jimbo74's Avatar
well first of all you should not have kept doing illegal and dangerous activites even aster the first mishap.... anywyas....
there are a lot of things that can be wrong, you could have easily damage any part of the suspension, tweaked the frame or do any type of serious damage, or nothing at all..... hows the driveability issue? is the steering whel upside down? same as it was before the idiocy? or does the vehicle have a pull? vibrations? clunking?
Old Dec 27, 2004 | 10:35 AM
Waterboy's Avatar
thanks grandpa, why you sure keep us kids in line
Just go get your alignment checked out that should tell you if something is tweaked. Sliding into a curb on ice shouldn't be that big of a deal unless you were going fast enough that the tire couldn't soak up the impact.
It sounds like you need the practice if you can't keep from hitting the same curb 3 times.
Old Dec 27, 2004 | 10:52 AM
superjoe83's Avatar
take it for an alignment, that "pop" could have been a lot of things, and to lift the opposite wheel off the ground took a decent impact, next time try doing reverse donuts, they are more entertaining and because you front tire is turned your more likely to run over stuff vs. slam into it
Old Dec 27, 2004 | 10:57 AM
lee's Avatar
lee
i hit a curb yesterday when taking a turn on a road... skidded into it, hit, then corrected right away.
but that curb was also covered in 12 inches of beautiful white snow (take that austin ).
so yea, nothing happened.
Old Dec 27, 2004 | 02:02 PM
kyle_22r's Avatar
if you hit your rear axle, you could've bent the axle shaft flange
kawazx636
Oct 6, 2021 03:03 PM
83yotastockR
11
Nov 10, 2015 06:54 AM
Dale Johnston
11
Oct 31, 2015 10:22 PM
bryan34w
12
Sep 30, 2015 02:50 PM
charlie_fong
Sep 27, 2015 10:06 PM
