Running cool.
Old Dec 25, 2004 | 05:18 PM
Bigblock's Avatar
Question Running cool.
My 1990 4 Runner gauge takes a long time to raise to normal. After letting it idle for several minutes and then driving it for 20 miles or so, it still reads below cool when it should read normal. The heater works fine, new thermostat and radiator. Just replaced the head gaskets and the heads and block are clean. I am baffeled by this, by all rights the gauge should at least register something after running that long. Any ideas are welcome as to what might the problem be.
Old Dec 25, 2004 | 07:13 PM
CrazyDiamond's Avatar
May not be a 'problem'. After doing a cooling system flush, radiator clean, painting my radiator with a black heat-dissipating paint (looks awesome), new high-flow water pump, and a high-flow t-stat, mine barely hits 180 degrees with the A/C on full blast in 98 degree summers. Right now, in winter, it runs around 165-170...can't get it higher. Runs like a champ. Yeah, it may affect emission a tiny bit, but it lets me run a bunch more advance without pinging...free horsepower!!
On the flip side, you should check your temperature sending unit...could be just giving a false reading.
Old Dec 26, 2004 | 02:09 PM
Bigblock's Avatar
thanks for the info. A cooler thermostat might help but I believe I have a restriction in the heater pipe under the intake
Old Dec 26, 2004 | 06:08 PM
TechWrench's Avatar
If you have an electric fan, check to see that it isn't running all the time. that would keep the temp down. Also if the thermostat was installed incorrectly (backwards), or the wrong range, it could cause that problem.
Old Jan 25, 2005 | 04:06 PM
Bigblock's Avatar
i should mention,it aint running cool,its running hot,but guage shows normal.
Old Jan 25, 2005 | 04:23 PM
jimbo74's Avatar
do you have the 2 stage or regular tstat? i am assuming a 22re engine? my oem tstat died on me in less than 6 months! jsut replaced it with the 2 stage
Old Jan 27, 2005 | 04:07 PM
Bigblock's Avatar
3.0 . What is a 2 stage?
Old Jan 28, 2005 | 01:52 PM
TechWrench's Avatar
Just two different levels of operation. A partial flow and a full flow operation, depending on temp level.
Doug4320
Mar 24, 2018 10:11 PM
calderp
Engine Swaps
Aug 16, 2016 05:15 PM
coffey50
Jul 28, 2015 10:55 AM
calderp
Jul 27, 2015 09:58 AM
smiley52
Jul 11, 2015 05:16 AM
