1996 exhaust gutted.
Old Dec 17, 2004 | 12:15 PM
YOTADEN's Avatar
I have a 96 tacoma 4X4 2.7. I was wondering if I gutt the converter out will it mess with the O2. If it does can anyone tell me what I can do so I dont have to get a new converter.
Old Dec 17, 2004 | 12:23 PM
Mystickal's Avatar
Bite the bullet, get a catalytic converter. The use of a vehicle on public roads without a catalytic converter is illegal. It is a violation of federal law to gut a catalytic converter. And it's environmentally irressponsible to run a vehicle without one.
~Bill
Old Dec 17, 2004 | 12:32 PM
YOTADEN's Avatar
96 tacoma
I know that it isnt the the thing to do but I dont want to shell out $425 for a converter at this point. This summer I am going to be putting a 302 V8 into it so if I can get buy till then it would really help.
TacomaTRD's Avatar
Get a high flow cat, they are around $100-120... If you gut it out I think it will screw with the O2, on my 94 22RE the previous owner gutted it out, you could tell when you knocked on the cat (sounded hollow), plus the exhaust was much richer smelling. We don't have emmision testing in NH, but I hear it's coming soon.
Old Dec 17, 2004 | 12:39 PM
RED 85's Avatar
Why do you need a new one?
Old Dec 17, 2004 | 12:58 PM
Mystickal's Avatar
Somebody's ripping you off if they want you to pay $425 for a new cat. Or you're at a dealership. And, no matter what engine you use, you'll be able to use the same cat (though you may need to have a different size inlet or outlet if you change the size of your exhaust - but you'd still be able to use the same core).
You can get a high-flow cat with either 2-1/2" pipe or 3" pipe from Road Race Engineering
~Bill
Old Dec 17, 2004 | 01:00 PM
YOTADEN's Avatar
I need a new one because I think that it is getting plugged up. I am not getting as good gas milage and have noticed it leaking around the converter. I have been to auto zone and checked it for codes and it showed everything being OK. I baby this truck on maintinance, Amsoil, bosch, and all the good stuff to keep it running like new. It has 113,000 miles on it so i am sure that it is due for one. Michigan does not test so it should be OK if I gutt it.
Old Dec 17, 2004 | 01:14 PM
TacomaTRD's Avatar
My 98 2.7 with 140K is the same way, no codes or CEL on. I go through front exhaust donuts, I am putting her up forsale so I'm not sure if I will put a new cat on. Do you feel like you have lost power too? Drop in mileage could be many things...
Old Dec 17, 2004 | 02:03 PM
YOTADEN's Avatar
Tacoma
I am willing to bet that your 98 is plugged also. That is why your frount exhuast dougnut is going bad. It just has to much back presure. I just hope this gutting wont mess up my O2.
Old Dec 17, 2004 | 03:00 PM
RED 85's Avatar
I would just take it off and see if you can unplug it first before you gut it, or try turning it around. If not just take a 1" bit and drill threw it.
Old Dec 17, 2004 | 06:30 PM
superjoe83's Avatar
if you gut the cat you will get a code like "catalyst efficiency below threshold" OBDII is very picky of these things
Old Dec 18, 2004 | 06:41 AM
TACOMANATOR's Avatar
If you take out or gut the cat you will get a code. You can get a new cat for $100 from Catco.
Old Dec 18, 2004 | 04:58 PM
YOTADEN's Avatar
Tank You guys for the info this forum is awsome.
Old Dec 18, 2004 | 05:28 PM
MTL_4runner's Avatar
Definately get an aftermarket high flow cat......you can use it later with the swap as well.
Your emissions will not be very good at all without it.
Zach_trun
Jan 22, 2020 04:42 PM
Corvoid
Dec 11, 2015 11:21 AM
alexcarey
Oct 14, 2015 06:05 PM
bryan34w
12
Sep 30, 2015 02:50 PM
voiddweller
Sep 28, 2015 11:21 PM
