Need help with a Bad squell (sp?)
Old Dec 24, 2004 | 01:16 PM
98limitednewbie's Avatar
Maybe the recent cold weather has something to do with it, I dunno. But I get this bad squell, sounds just like a squecky belt. But I only hear it when driving, and even then only when I'm not gassing the motor. It squecks only when coasting above 20 mph. Sounds like its coming from underneath the vehicle. So what do you guys think? Is it the belts? Or something to go with the driveshaft?? BTW 98 4x4 w/ 3.4. And I'll look up how to spell squell right now. TIA!!
Old Dec 25, 2004 | 02:50 PM
98LimitedCustomized's Avatar
I assume you mean squeal, as in a high pitched noise? I'd pop the hood and have somebody rev the motor (not too much, not too long....) and see if you can't hear it better.... hopefully it is just some belts slipping... while you're add it check all your fluids, if you're not sure how look in the technical articles section of yotatech. Good luck!
ghostmoney
Jan 28, 2018 11:42 AM
Blamalam
Aug 16, 2015 12:29 PM
corey519
Aug 12, 2015 11:12 AM
nonstop
7
Aug 11, 2015 09:26 AM
keithporter83
Jul 18, 2015 12:37 PM
