CV boot kit - which grease to use?
Old Dec 23, 2004 | 01:35 PM
KZN185W's Avatar
I recently had the outer cv boots replaced with a Toyota CV boot kit. The box came with two grease packs, a white one and a yellow one. Which one should be used and where?
Does each one have a specific use? The box didn't come with instructions.
What the mechanic did was mix the two and applied the mixture. Was this correct?
Appreciate any help. Thanks.
Old Dec 23, 2004 | 01:51 PM
arielb1's Avatar
I would not mix the two grease together. If you need to, call the place you bought them from and ask which to use and where. Also, see if the manufacture has a website you can reference.
I purchased the entire axel when my boot failed. I just R&R and did not have to mess with the rebuilding of the CV boot. It was fairly easy. It is great to have a second person to help though. g/l
Old Dec 23, 2004 | 04:22 PM
Robinhood150's Avatar
The mechanic mixed the two?!
The grease is specific for the outer and inner joints. I don't know which is which for your 96.
Old Dec 24, 2004 | 02:09 AM
Bighead's Avatar
The outboard joint gets the Black grease. The inboard tulip joint gets the Yellow grease.
Old Dec 24, 2004 | 11:12 AM
Ironmike4x4's Avatar
Yellow goes in black goes out. They shouldve put the intructions in there but they are a different grade or something so make sure they go in the right places.
Old Dec 25, 2004 | 02:23 PM
KZN185W's Avatar
Thank you so much guys!!
What is the reason why different grades of grease are used? Which among the two is the higher grade?
Thanks again!!
Merry Christmas!!
Old Dec 25, 2004 | 02:35 PM
keisur's Avatar
different types of bearings require different greases.
Old Dec 25, 2004 | 04:31 PM
I dont know how it is on the cv joints but I think needle type bearings need a thinner grease? It might be the other way around but the ball bearings use which ever is opposite to the needle bearing.
RyanJ989
11
Apr 7, 2021 09:41 AM
justdifferentials
14
Jun 11, 2017 08:36 PM
RickyD
Oct 2, 2015 07:53 AM
Regency
Sep 6, 2015 05:47 PM
justdifferentials
Sep 5, 2015 06:52 PM
