- Fuel gauge innacurate
- VSC initialization speed - 2002 SR5
- What size socket do need to remove rear shocks
- E-Locker Wiring Help Please
- 3.4 L V6 Cooling issues at high RPM
- More road/engine noise after clutch replacement?
- 96 tacoma with "thump" in rear
- replacing alt fuse
- Having alignment problems after installing lift 2000 4runner
- 3rd gen 4runner rear axle shafts help
- Bilstein 5100 and OME 906 question
- Question on Dealership Quote for work?
- An ugly mod I saw, while I was out today.
- Upper Control Arm
- 1999 toyota s.c, 7injected 4runner: throwing code/hesitation
- Pesky 0401
- 5VZFE Valve cover spark plug gasket removal tips needed...
- 1/4 window latch replacement
- Starter inop after engine swap.
- New Timing Belt Water-Pump 5vz-fe 3.4L Write-up for Review
- Antifreeze leak? Mix? 2000 4runner 5VZE
- Key CB and engine dies?
- 2000 Tacoma Steering Loose
- Torque OBD II App does not detect AF (Upstream O2) Sensor?
- 31x10.5 Tire on 15x7 wheel?
- New Vibration
- Help needed. Dome light trigger wire.
- Intermittent Grinding Noise Front Right
- Spark knocking help
- Silverston SS brake lines?
- High Angle CVs or Manual Hubs?
- ARB Bumper on a 97 4runner
- 5spd swap, HERE GOES NUTHIN!
- HVAC knob doesn't change air flow direction
- weird liftgate locking problems
- Another stolen Cat!!
- Are T100 compatible to 4Runner injectors?
- Another bad wheel bearing! why?!?!
- brake problems
- No Low beamhead lights need diagram
- ADD/Manual hub t/case
- 1" body lift is on!!
- Master Cylinder (?) Noise in 2002 4Runner
- Stabilizer Bar Broken - Dangerous?
- Custom 3rd with TJM Locker Install
- What are these interior trim pieces?
- What have I got here?
- 1997 Toyota 4-Runner Cruise Control Problem
- Need help tracking down parts
- Major engine trouble: whining, sputtering and popping
- 02 4runner Fuse Block - Something Wrong
- 1998 limited 4 runner rear wiper/window not working
- Plug wire longevity? 3.4 V6
- Aweful buzzing noise when cold, 96 taco
- To use OEM shocks... or not use OEM shocks... that is the question
- CV SHAFT...Manual vs ADD Hubs
- BIG PROBLEM after replacing spark plugs
- 1995 Taco, 2.7, dead throttle at half throttle
- E-Locker Factory Wiring Install
- turns over, won't start...efi fuse
- Rack and pinion/ball joints
- 3rd Member Installation 3rd Gen 4Runner
- 2RZ-FE Timing Chain Cover Question (I think I broke it!)
- Brake lights??
- Even More E-Locker Questions...
- 100 feet=burnt clutch
- Clutch pedal bushing ... NOT THAT BUSHING
- Help programming Keyless Entry
- Beware: Power Steering air control valve
- Need some help fellas P0125 & P1130
- Exterior door handle swap question
- 2004 dome light not working
- Will 4th gen stock nerfbars fit on my 3rd gen 4runner?
- tire wear
- oil cooler cause overheating??
- What is this air line?
- Rear diff fluid type in 2wd
- Convert SR5 4Runner to Limited?
- Odometer Problems
- Fender flare help! 01 sas Tacoma
- 96 SR5 4 Runner - stopped running
- Ratteling in Steering Wheel
- Lower radiator did not heat up at all after changing cooloant
- 3rz-fe crankshaft replacement
- 1998 4runner limited overheating still
- P0446 help
- recent 3.4 swap wont run monitors
- Any way to check for a broken timing belt?
- Major Fuel Leak upon Engine Startup. Cant find leak.
- DIY '96 4Runner Upper Ball Joints
- 98 2.7L 4runner 4wd not engaging`
- new chrome bumper
- Price list book?
- To-Do List? New-to-me 98 V6 5sp 4x4
- Power locks going crazy
- E-Locker Factory Switch Wiring Help Needed
- 5vzfe 3.4 Over heated! Warped heads!
- 2001 4runner ARB bumper replacement
- new to Tacoma's have 3 questions!
- more power needed, opinions needed
- Need 3.4 Injector Installation write up
- Easiest way to remove fuel pump 96 taco
- should i flush the tranny
- Help diagnosing an A340F transmission
- up to my armpits in timing belt change...
- 2001 4Runner sputters between 50 - 60 mph
- Will '01-'04 Taco interior pieces retrofit into a '97?
- Tundra knuckle and balljoint on Tacoma
- Rear hatch pin switch for cargo light
- when should my gears shift? (automatic)
- Results of 203K valve clearance check
- 1997 Toyota 4Runner 4x4 6 cyl cranks but wont turn
- Correct Tundra coils?
- I Got a New Truck Today!
- How long do you keep your frost plug heater plugged in for?
- Driveshaft/U-joint info
- P0306
- Should My Tacoma Have an IAT Sensor?
- Ignition Coil??
- How much can I tow?
- 2000 Tacoma Speedometer problems
- Need suggestions. High idle(850-950) hard start poor mpg
- '97 T4R-Manual. Clutch Recommendations?
- Problem with 4wd in 98 non-multimode tc
- Review of Bilstein HD and 99 front spring / OME 906 lift
- 150K maintenance; What would you do?
- 98 Runner 'whirring' issues
- Third power Steering pump
- Vibration Drive train
- Has anyone replaced a fuel tank?
- RPM Surging on '97 T4R, 5-SP
- 01 Trd supercharged Tacoma. Can you get a bov?
- 2003 Taco Fuel Gauge Issue...
- Help needed: No starter motor after engine swap.
- Slippin tranny?
- 99 4runner won't shift out of 2nd gear when cold
- Sucking Noise coming from passenger side, vibration
- Please help with unknown wire connector
- Manual vs Auto.. is it worth it?
- Help me identify these electrical parts
- 1995 Tacoma 2.4 with elusive misfire
- 4Runner stops reving at 4000 RPM
- Junkyard 3.4 w/ 71k: Install "As-Is" or Rebuild?
- 5VZ-FE installing oil pressure guage
- Need help identifying year of motor
- Coolant Leak
- Just did shocks/struts - rear sag ?
- 2.7 performance
- Abs codes
- drilling shock buckets
- 1999 4Runner V6 a/t slips when letting off gas.
- Popping Noise from Accelerating and Decelerting
- Painting a Supercharger
- 4WD not engaging in 97 LTD 4runner
- Tail light bulbs
- Paddle shift 4runner project
- Horn Button
- 96 3.4 4runner overheating and stumped
- Timing Belt -what would u do?
- Front end clunk when braking/starting
- Reading Vin Codes
- Newbie saying hi
- Oxygen censor
- trick to install tumbler?
- Awful noise coming from rear end? T-case?
- 98 Runner battery draining to dead
- 96 4 Runner rear window problem.
- looking for a part number
- Timing Belt reaplcement Q's
- starter will not turn off????
- 2002 4Runner rotational noise
- Tranny/Power Steering Leak
- OEM vs Aftermarket CV Shaft Identification
- URGENT HELP. Rear differential
- 98 4Runner Limited 4WD light not working, but partially engaging? Help please
- Help interpreting compression test results.
- 98 V6 Tacoma Head gasket issues
- 99 taco with famous 6 inch trail master
- Pro line radiators
- White Smoke & Wet Block
- more light for me no more glare in your face
- some timing belt questions...
- lift just enough to clear 265/75/16 firestone M/T's
- Driveline whine/whir diagnosis
- OEM rear locker not working.
- 99 Limited Need Front Mud Flaps
- Interchangeability Between Tacoma 3rz-Fe and 4runner
- 3rd gen 4runner : Cheap way to fix stability? (Scary highway feel)
- long travel front end
- Budget replacement Springs
- Advice Needed - 2002 T4R with bent rear axle housing
- Bought a new truck, couple questions
- What did I break? Pic inside
- About to Herculiner my rocker panels
- What is this on the engine circled in red?
- 02 Tacoma 3.4L Issues
- Double Cab 5-Speed
- BRAKE Problem
- Airbag
- Difference between short block and long block 3RZ
- 2000 4runner losing anti freeze at bottom of engine
- i have 33 12.5 and wanting 35" tires, look please
- Toyota Truck, 4Runner, Tundra Balljoint Failures
- FJ Style modifications
- Help me find squeak/chirp at idle
- Looking for suggestions on a new DD Taco 2.7
- 98 tacoma 3.4 supercharged more boost
- Transgo Auto shift kit
- replace all weatherstripping on 01 4runner?
- 02-04 limited taco dor locks
- Stupid P0171
- 98 Bed Fitment
- 3.4L Automatic Transmission Fluid Cooling Lines
- tire questions
- Bilstein 5100s on the way, question about progressive add a leafs!
- Catalytic converter protection
- have poping in front end
- Grill Guard
- OME 890 springs side A/side B
- Is my truck a 22r or 22re?
- dashpot repair for 3.4L?
- Middle of OME 890 Install - Need Help!
- Squeeky clean
- Bilstein 5100s will fit a stock truck right?
- Tacoma 2.4L X2Rz-N74 99 and Knock Sensor
- TPS Problems
- SUDDEN LOSS OF POWER! When Jump starting sparks are flying & Still no Power.
- Blow By on a 3RZ-FE with 166k
- 07 TRD Hood dimensions?
- 2.7 stick stalls when cold
- Video containing general info: 1998 Supercharged 4Runner
- I was told my double cab looks lowered yesterday :( new OEM springs or? to restore it
- Intermittent problem: Engaging 4wd
- lost all electrical power
- checking fuel injectors...Help
- Detroit Locker & Daily Driving
- Instructional Video: Jeff's way to rotate your tires
- Driveshaft binding in to the rear differential
- Trying to find out who makes a specific rear bumper
- Question about inner axle seal install.
- 1998 toyota 4 runner break problems
- 1998 4runner Will not Start
- truck gas/power steering shutoff + CEL
- Speedometer Issues on my 96 Tacoma 4x4
- 3.4 5vz-fe engine removal 2001 4runner 4wd
- Advanced knowledge of 3.4L harness
- 2.7 4runner wont start.
- 96 T100 PCV cross over tube?
- 99 4Rnuner 5spd clutch / tranny issue(s)
- 4WD in limbo
