What size socket do need to remove rear shocks
Old Jan 18, 2012 | 03:00 AM
YodaPala's Avatar
For a 1999 4Runner, I'm talking about the top nut on the stem. Thanks
Old Jan 18, 2012 | 04:40 AM
habanero's Avatar
Assuming it's not a solid rust knot.....B'laster, a hex L-wrench and a box end wrench. I can't picture how you'd get a socket in there and keep the thing from just spinning.
Old Jan 18, 2012 | 04:55 AM
Nelsonmd's Avatar
14. A deep socket worked well for me, you might find good results with a short extension and a standard socket.
If you have a good amount of rust, then you might find it is easier to just cut the shock off instead of trying to unscrew the nut.
Old Jan 18, 2012 | 05:38 AM
waskillywabbit's Avatar
You want a 14mm mid socket, in between the length of a deep well and normal socket.
:wabbit2:
Old Jan 18, 2012 | 05:42 AM
habanero's Avatar
Ok, that's it, I'm going to have to go out in the cold to see what you guys are talking about. I must not be remembering it correctly.
Edit: No, it was as I remembered it. How are y'all keeping the rod from spinning while you loosen the nut? Open end ratchet? Or am I the only one special enough for that sort of problem?
Old Jan 18, 2012 | 06:39 AM
enapa's Avatar
Vice grips? Lmao
Old Jan 18, 2012 | 07:18 AM
Leviticus6432's Avatar
I used a pipe wrench on the shock lol didn't end up looking pretty but who cares, I was putting a new ones on anyway
Old Jan 18, 2012 | 08:28 AM
4byrunner's Avatar
Are you replacing the shock? If so a sawzall will "fit" perfect
Old Jan 18, 2012 | 12:18 PM
habanero's Avatar
Originally Posted by enapa
Vice grips? Lmao
Ah, gotcha. Pleased to give you a chuckle.
Think I'll stick to my little hex wrench then, or just cut it off if it's too rusty.
Old Jan 18, 2012 | 04:59 PM
baddest94's Avatar
Everybody beat me to it cut it off to much work tryn to hold them LOL
Whatever123
Sep 30, 2015 12:12 AM
Sep 4, 2015 09:27 AM
icentropy
Jul 9, 2015 02:12 PM
87turboPA
Jul 9, 2015 05:58 AM
ItsJustD
Jul 7, 2015 07:49 AM
