Advanced knowledge of 3.4L harness
Old Nov 3, 2011 | 09:29 PM
cpizzle42's Avatar
Anybody on here know the ignition and ecu wiring on the 3.4L inside and out and how to diagnose problems with it?
I am working on a short course race truck, and just about to give up on it after working on it every night this week after work.
No spark....
'02 4runner ECU. 3.4L S/C with URD 7th inj kit.
Old Nov 12, 2011 | 08:12 AM
dntsdad's Avatar
I dont know it inside and out but no spark would be caused by the White/blue wire not getting power, or the body of the ignitor not being bolted down to a surface that is providing ground. The ignitor gets its ground through the mounting bolt and not a wire.
Old Nov 12, 2011 | 09:31 AM
paynemw's Avatar
you're in luck... I just had a wire harness issue. I didn't do the work but I will try to relay as much info as possible to you. The EFI fuse covers two circuits, (don't recall the names of them) but one circuit covers all 8 or so sensors related to fuel injection (crank position sensor, cam position sensor, throttle _____ sensor, etc) the other runs to a connection at the ECM. I'm sure you've already checked your coil packs with an ohm meter.
mussy01
Dec 13, 2016 08:20 PM
toofly1999
Jul 25, 2015 07:09 PM
1996Taco
Jul 20, 2015 12:02 AM
Seattle_Sign_Guy
Jul 12, 2015 12:38 PM
