1998 4runner Will not Start
Old Nov 6, 2011 | 05:31 AM
kn1dmay1's Avatar
My son was driving his 1998 4runner 3.4l v6 limited 2wd the other day and he said it just shut off while driving and he had to coast to a safe place to stop. Now it turns over like normal but just won’t start. I took one of the plug wires out and placed a screw driver in it and when we crank it there is no spark. I have a 2001 4runner and I repeated this in it to make sure it would even work and I got spark so my test process worked. I tried two different wires and no spark. I checked the ohms on one coil pack and it was within the range. I checked the wire going to the coil pack both at rest and while cranking and there was no DC voltage. My first questions would be is this normal?
Second I tested what I think is the camshaft sensor on the front side of the motor on the opposite side of the battery. The ohms appear to be in range and I tested AC voltage while cranking and it seemed ok as it did change values. So I am left with what I think are the only three components that could cause this; Crankshaft Sensor, Igniter, and ECM. Could the Crankshaft sensor cause this or should I be looking at the igniter or ECM?
Thanks in advance for any help!!
Old Nov 6, 2011 | 05:40 AM
rworegon's Avatar
Have you checked all the fuses? COR (Circuit Opening Relay)?
Check out the Diagnostics section in the FSM:
http://www.ncttora.com/fsm/index.html
the1998sr5
Oct 19, 2016 12:48 PM
camdenbuck
Jul 7, 2015 07:33 AM
B. Graves
Jul 3, 2015 04:10 AM
P51warrior
Jun 25, 2015 05:50 AM
ACZR
Jun 23, 2015 07:55 PM
