ADD/Manual hub t/case
Old Jan 6, 2012 | 07:08 AM
terminator's Avatar
Question: I have a 96 4Runner 3.4 with ADD and auto trans. Is the t/case from a 97 Tacoma with manual locking hubs the same or are they different?
Thanks
Jason
Old Jan 6, 2012 | 09:26 AM
scuba's Avatar
Manual locking hubs has nothing to do with transfer case selection.
The main differences between transfer cases is "Jshift" or "push button" gear selection and which engine/ transmission combo the case came off of.
You need a transfer case off of the same engine and trans combo that you currently have.
If you already have a Jshift case, don't get a push button. If you have a push button case, you can convert to Jshift easily with minor wiring modifications to make everything function properly. Jshift cases are obviously more reliable than the push button cases due to not having the gear switching electrical actuator on the back of the case.
Old Jan 6, 2012 | 09:39 AM
terminator's Avatar
Thanks, I wasn't sure if there was a difference or not and I appreciate the info on this. I'll keep the t/case as I'd like to eventually go manual swap one day.
ladybugRC
458
Aug 21, 2020 10:41 AM
G-off
Dec 29, 2015 12:44 PM
AaronM
12
Nov 4, 2015 04:06 PM
stanz
Oct 30, 2015 10:33 AM
Toys4parts
Sep 26, 2015 01:56 PM
