Vibration Drive train
Old Dec 10, 2011 | 12:19 PM
mjeffy's Avatar
I have vibration issue in 2003 tacoma double cab with 184000 miles 4 wheel drive with trd,while accelerating. When I let off the gas vibration goes away as soon as I get back on the gas it rattles my whole dash. All u-joints are tight. When i lift both rear wheels and spin tires I can hear the clunk and wheel has some play passenger side is worse than driverside. Also with wheels up engine on and in gear i can see the wheels wobble around 80 mph. Is this symptoms of axle bearings or something in the rear diff ?
Old Dec 11, 2011 | 07:48 AM
Texas_Ace's Avatar
I would start out by changing all the fluids, always start simple. Change the fluids with some high quality fluid, can even put some lucos in them if you want and see if that helps anything.
Then go from there.
Old Jun 4, 2012 | 07:35 PM
yodta's Avatar
Jeffy - you ever find a fix for your prob?
Old Jun 4, 2012 | 07:41 PM
mjeffy's Avatar
I did!!! it turned out to be the rear u joint.. the driveshaft would not move when I got up under the truck in the truck to move the drive shaft. I had to get a friend of mine help me. well I shifted to gear shifter from drive to neutral several times he held on to the drive shaft and could see and feel the driveshaft twisting. I got all the u joints replaced and the cv joint serviced new carrier bearing and the driveshaft balanced all for around 300 dollars. it drives like a dream now... thanks for asking!!
Old Jun 4, 2012 | 07:46 PM
ThatGuy1295's Avatar
Ya?
I have a vibration simular to yours, except 01 taco 5 speed. Mine occurs only in 5th gear below 60mph, and only if I'm on the throttle. Very consistent, and very noticeable. Checked U-joints, and carrier bearing, all seem fine. Very annoying. I hope its not trany, but also hope its not as stupid as tire balancing either.
Im actually at this point hoping it breaks, just so I can figure out what the ---- it is.
Old Sep 9, 2014 | 04:25 PM
Swede's Avatar
Originally Posted by ThatGuy1295
Ya?
Did you find out what the culprit was? I'm getting the same vibe at around 50 mph. Only in 5th gear and only on acceleration.
Old Sep 9, 2014 | 07:09 PM
Sadly it turned out to be my transmission. I found large peices of metal in the gear oil. I had it fully rebuilt and havent had a vib since. Was a couple bucks$
jasonty
41
Dec 23, 2018 01:00 PM
Tykiller1994
Aug 10, 2015 07:49 PM
kyletbert
Jul 17, 2015 11:39 AM
Poncho0206
Jul 10, 2015 06:21 PM
Jnkml
Jul 6, 2015 01:20 PM
