OME 890 springs side A/side B
Old Nov 11, 2011 | 09:41 PM
4x4Forner's Avatar
I just got some ome 890 springs and did not have time to do it myself, so i had a mechanic do it. I was told to put spring A on the driver side because it is a little longer to compensate for driver side lean. anyway the mechanic put spring B on the driver side and A on the passenger. should i switch them? is it that big of deal?
Old Nov 12, 2011 | 06:13 AM
waskillywabbit's Avatar
Make the mechanic do what you paid him to do and do it right.
Yes it will matter.
:wabbit2:
Old Nov 14, 2011 | 08:42 AM
IanB's Avatar
X2, have him switch them around. Did you measure the height on each side to see if they are different?
Old Nov 15, 2011 | 10:22 AM
4x4Forner's Avatar
that's the thing, i measured it and its all pretty much even. the passenger side is maybe a 1/16" or 1/8" taller. since its sitting pretty nice i was thinking about just leaving it as is. but then again i want every thing to be installed the right way so that in the future it will still be workin the way it should. thanks for the help
Old Nov 15, 2011 | 10:27 AM
Sensei's Avatar
As stated above, you paid for an installation to be done correctly. It's the responsibility of the tech to correct his/her mistake. If you don't hold him/her accountable, who will..??
88sasturbotoy
Jan 30, 2026 01:57 PM
Flying91
45
Apr 11, 2024 04:39 PM
yourrealdad
Jul 21, 2015 11:13 AM
Nickdigg
Jul 7, 2015 06:04 AM
MTLroadierunner
Jul 6, 2015 12:17 PM
