Old Mar 31, 2016, 09:15 AM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Toyota 4Runner Specifications & General Maintenance
Print Wikipost
Reading Vin Codes
Old Nov 29, 2011 | 01:32 PM
Super6's Avatar
Reading Vin Codes
Hello,
I was contemplating moving to a set of larger tires and wanted to know what axle ratio I had on my 01 4Runner. I took my vin to the dealer and they were no help. Short of pulling things a part, is there a way to figure things out?
It has the 265/70/16 tire package on from the factory.
I've run across a few sites but each one ends up with a different result.
VZN185L-GKPGKA
C/TR 1CO/FA17
ATM A04A/A340F
According to this site I have 4.10s
http://www.vibratesoftware.com/html_...rive_Axles.htm
According to this site I have 4.56s
http://www.brian894x4.com/Gearratiosanddiffs.html
I suppose I can take get it up to cruising speed a get an RPM reading but I was hoping to be more technical than that. Any suggestions?
Thanks
Old Nov 29, 2011 | 01:39 PM
toyotaPmanager's Avatar
PM me the vin and i will find out for ya
Old Nov 29, 2011 | 01:48 PM
xxxtreme22r's Avatar
ATM A04A/A340F 4.56's. I trust Brian's site over that other one.
Especially when this one says you have 4.56's too. http://www.off-road.com/trucks-4x4/t...ion-18588.html
To my knowledge vin numbers DO NOT contain the gear code info, that's what the gear code on the vin plate is for.
Old Nov 29, 2011 | 01:53 PM
Hope this helps. sorry the quailty is not great. first one is published by toyota. second is a look up for ring and pinion off toyota's fish
actually toyota shows it as a 4.30
Old Nov 29, 2011 | 01:54 PM
Super6's Avatar
PM sent.. just in case. I'll take it out on the highway in the next few days with O/D off to double check (snow flurries currently). If memory serves me the tach hovers around 3000 ish.
What's the old formula? RPM = Gear x MPH x 336 / Tire Height in Inches? Wow that was fast, I'll have to road test to figure out the difference between 4.30 or 4.56...
Thanks!
Old Nov 29, 2011 | 01:55 PM
scuba's Avatar
Right but 4.56's only came in 4 cylinder 3rd gen 4Runner's. And even then it was a rare option. Op has an 01 and 00 was the last year of the 2.7 for 3rd gens.
The gear charts have been notoriously wrong for 3rd gen 4Runners.
I think he has 4.10's.
Old Nov 29, 2011 | 01:56 PM
THis guy here:http://www.ttora.com/forum/showthread.php?t=6862 Had this same issue, He confirmed 4.30's. Stupid Toyota. lol.
Old Nov 29, 2011 | 01:58 PM
scuba's Avatar
Thanks!
Plug your numbers in with possible gear ratios and when you get the right ratio the numbers will match up.
http://www.grimmjeeper.com/gears.html
Old Nov 29, 2011 | 02:03 PM
just got his vin and ran it. It was factory 4.30 just as the chart i posted earlier shows.
Old Nov 29, 2011 | 02:35 PM
Super6's Avatar
Seat of the pants foggy memory response supports your results toyotaPmanager.
Converting back from 100km/h is roughly 62.1mph and a 4.30 ratio on 30.6" tire works out to be 3011 RPM. The result "sounds" about right. I will double check and get back to you when the skies clear.
Thanks again!
Old Nov 30, 2011 | 08:06 AM
Nelsonmd's Avatar
You should search this topic as it has come up multiple times. I went through the same thing, and every chart either got it wrong, or offered multiple options for gear ratio. Even dealerships have looked up people's ratios and gotten it wrong. Before you waste any money buying a component that is the wrong ratio, just do the actual measurement...
Do the spin test. It is very easy, and is relatively foolproof. Certainly way better than looking up on a random website (Brian's site got mine very wrong), or asking a dealer to look it up. Check out this thread:
https://www.yotatech.com/forums/f2/h...-ratio-234336/
It has the spin test method, and another method from Scuba. Both are better than just going by VIN or axle code.
EDIT: Oh, I see Scuba already chimed in with his method... I still think the spin test is better...
Old Jan 5, 2026 | 06:15 AM
Rapha10's Avatar
Decoding VIN codes for the first time can feel like learning a whole new language, especially when you’re trying to figure out what all those letters and numbers actually mean. I went through that myself when I first started looking into older vehicles and wanted to understand exactly what options were on mine versus what was just assumed. One tool that helped make sense of it was doing a toyota window sticker lookup through https://carfast.express/en/window_sticker/toyota because seeing the original factory build details gave real context to what the VIN was telling me. Once you see how it all connects, reading those codes becomes way more useful, especially when it comes to ordering parts, checking compatibility, or just satisfying your curiosity about how the car was built.
traxxi2003
21
Mar 24, 2022 10:32 AM
Bob_98SR5
7
Dec 30, 2011 09:54 AM
GobBluth
Feb 21, 2009 02:25 AM
Bejiita
Apr 25, 2007 08:54 AM
breakerfalls
Jun 10, 2004 10:02 PM
