Help interpreting compression test results.
Old Nov 25, 2011 | 02:36 PM
WestEnd's Avatar
OK guys, I need your help. Never done a compression test before, so I'm not sure I did it right.
1998 Tacoma with the 2.7L and 5-speed.
Warmed truck up for about 3 or 4 minutes. (enough?)
Cylinder 1- 135psi
Cylinder 2- 149psi
Cylinder 3- 150psi
Cylinder 4- 147psi
  • I have a MIL code of P0301... Engine Misfire #1.
  • The #1 plug is black, but not wet.
  • The rest look almost new.
  • Passenger side of block is obviously leaking coolant
  • and maybe even oil. (oil pan gasket?)
  • Radiator was low on coolant (couldn't even see it)
  • Can't tell where it's coming from
  • Engine backfires when you give it throttle.
I'm leaning towards a head gasket, with the coolant loss and fouled plug and #1 misfire.
Any other thoughts??
If it is a head gasket, with those Compression readings, should I look for a different motor?
Thanks for the help!!
Old Nov 25, 2011 | 02:38 PM
WestEnd's Avatar
Oh... I forgot... During compression test, I held the throttle wide open and cranked it two times for about half second each crank. Is that proper ?
Old Nov 25, 2011 | 08:39 PM
zlathim's Avatar
When I check compression, I usually let the engine crank for 4 or 5 complete revolutions. You may have shorted yourself a little, but the numbers don't seem to reflect it.
I would perform a cylinder leak down test next. If it is a HG, you will get air leaking through the cooling system. Look for bubbles in the radiator.
moparbay
Mar 10, 2023 03:50 PM
_Nicco_
Sep 21, 2015 03:06 PM
gyroscope7
Sep 21, 2015 04:55 AM
Boomer8404
Sep 10, 2015 09:01 AM
