Front end clunk when braking/starting
Old Nov 29, 2011 | 01:53 PM
NwRunner's Avatar
This seems to be a recent problem, or I just havent noticed it until now. Most of the time when im in stop/go traffic every time I brake or step on the throttle from a stop I will get a dull clunk that comes from what seems to be the passenger middle to front tire area. It sounds like setting a heavy glass cup on a wood table or a beam settling in a house.
I had my girlfriend rapidly start and stop yesterday but couldnt hear anything outside the vehicle except the rear driveline. Heres a list of things I checked yesterday that I thought could be making the noise but arent.
Brake caliper bolts
Lugnuts
F/R Driveline
Upper/Lower shock mounts
Springs contacting spindle
Swaybar endlinks
UCA Bushings
Differential mounts (1" diff drop)
Does anyone have any ideas? I have no idea what a bad CV sounds like, my boots are still intact (barely), LBJ's have around 10k, brake pads are new. My LCA bushings look fine, and i cant see them move when slamming on the brakes. This noise is driving me crazy.
Old Nov 29, 2011 | 01:58 PM
Philbert's Avatar
I had this in my Datsun earlier this year and it was a missing bolt/bushing on the tension rod (holds the front control arm to the frame). I had checked the caliper bolts everything, thinking it was a brake issue.
But it appears you checked everything. My money is on a suspension component still for your situation - did you check everything while it was load bearing, or up on stands? I'd check while it's up - that way you can wiggle things and see if they move.
Good luck!
Old Nov 29, 2011 | 02:04 PM
NwRunner's Avatar
Ive checked it on and off stands, cant get anything to wiggle without a 2ft prybar. This problem has been happening for about a week now and just today my gear selector on my trans got stuck in park and it took about 5 minutes of wiggling to get it unstuck. Now its sloppy between N and R and still trys to stick in park. Not saying these issues are related but thought id throw it out there.
Old Dec 3, 2011 | 07:58 PM
bassbro1's Avatar
Check ALL suspension and steering components. Your CV joints will click or tap when turning. Have you checked wheel bearings. Possibly brake components. Did the vehicle operation change when you heard this sound? Could this sound be something loose in the glove box? Do you have a way to put a mic or video under vehicle while driving to share the sound so we can help with diagnosis?
Old Dec 13, 2011 | 06:10 PM
SLOYOTA's Avatar
check your sway bar bushings and steering rack bushings
Old Dec 13, 2011 | 11:55 PM
NwRunner's Avatar
Rack bushings are fairly new and it still does it when the swaybars deleted.
Its gotta be the LCA's, Ive checked everything else and those are the only things that could still be doing it. I ordered energy bushings from Toytec should be installing them sometime this month
Old Dec 14, 2011 | 03:09 PM
rworegon's Avatar
Even though your LBJs have only 10k on them, is one or both failing in addition to the LCA bushings?
Old Jan 10, 2012 | 11:42 AM
NwRunner's Avatar
If there was enough play in my LBJs to make noise you would think I would have ran over my own tire a long time ago.
I replaced my LCA bushings and it did nothing. Energy suspension bushing are a PITA to install, you have to burn and cut the rubber off the OEM bushings because you must re-use every metal piece.
Could a CV be making this noise? Finally blew the boot and will be replacing shortly
Old Jan 10, 2012 | 12:12 PM
Newby's Avatar
Check your CV Axle and Bearing. They might loose or bad.
Old Jan 15, 2012 | 06:21 PM
boxer.fan's Avatar
Does it seem to pull to one side when you are almost at a complete stop then again as you release the brake, but not all the time??? Just asking because I just now am starting to get this after installing a 4" lift. I first thought that the brake rotor had grease and was just slipping at that point on the rotor when brake was applied but I addressed that by cleaning them off but still happens to me. I will subscribe.
Old Jan 16, 2012 | 09:19 AM
4byrunner's Avatar
My "clunk" went away went away after having my driveline lubed up. Most places will do it for free like jiffy lube or the like.
Mine was doing the clunk when i'd stop at a red signal then release the brake. Check it out before you start tearing stuff apart or spending money. This is a potential fix and it's free and takes only a few minutes.
Good Luck
Old Jan 16, 2012 | 09:28 AM
4byrunner's Avatar
A little more description/info,
The clunk after letting off the brake pedal is very typical of driveshaft slip joint needing grease. The slip joint will bind up a bit as the brakes are applied which loads the rear axle. This load is released once you let off the brakes and can give an audible 'clunk'. This is especially true after a hard stop.
Lube all u-joints, slip joints with a TON of grease. The grease gets old and dries out. Good luck again.
88sasturbotoy
Jan 30, 2026 01:57 PM
Flying91
45
Apr 11, 2024 04:39 PM
jasonty
41
Dec 23, 2018 01:00 PM
Sep 4, 2015 09:27 AM
Daneums
Aug 20, 2015 05:36 AM
