Coolant Leak
Old Dec 5, 2011 | 02:47 PM
evanh3's Avatar
Coolant Leak
I have a 1998 toyota tacoma 3.4L V6. I have noticed coolant under the truck. The radiator is full and the reservoir is half full every time I check it. Looked everywhere for coolant leak cant find one with and without it running. When my truck is cold my belts make a very quiet squeal until warmed up its been about negative 10. Temp gauge works fine. Where is the coolant coming from? I replaced the timing belt and water pump and 100,000 miles and now I am at 157,000. Thanks
-Evan
Old Dec 5, 2011 | 03:25 PM
rworegon's Avatar
Most obvious is the hoses and the water pump after pulling the timing cover. Wipe everything down under the rig and look for the run line of coolant.
Also, look through the wheel wells and between the firewall and engine focusing on the head/block interface. You're looking for wet spots and/or crusty red or green deposits depending on what anti-freeze you are using.
How does your oil look on the dipstick and through the valve cover oil fill hole?
Old Dec 6, 2011 | 01:32 PM
evanh3's Avatar
Oil looks fine. What would happen if I drove and water pump quit working? I have to make a 100 mile road trip this weekend no time to replace it yet.
Old Dec 6, 2011 | 01:46 PM
Bassmastry101's Avatar
Your engine would overheat..no water no cool.
Old Dec 6, 2011 | 02:48 PM
rworegon's Avatar
evanh3,
And, then potentially this:
http://www.ultimateyota.com/index.ph...6&topic=2241.0
Old Dec 6, 2011 | 06:41 PM
James Woods's Avatar
I know it is pretty basic but are you sure that it is coolant and not your evap drain hose?
Old Dec 7, 2011 | 04:30 PM
evanh3's Avatar
Ya its coolant. Sometimes there is coolant under truck other times none. I was looking around online. Someone said they had issues with gasket between water pump and engine. I took off timing belt cover and didn't see anything out of the ordinary.
Old Dec 7, 2011 | 05:08 PM
rworegon's Avatar
Good on the WP. Grab a mechanics mirror and flashlight for a good inspection of the head block interface, hoses, radiator, etc. Some have had the coolant recovery tank crack too.
Once you find the area where the leak is originating, we will likely have more suggestions as to probable cause.
Old Dec 13, 2011 | 08:07 AM
DailyDrive's Avatar
This doesn't make sense. You observe the same amount of coolant in radiator and reservoir yet there is coolant on the ground? Or are you adding coolant when you see coolant on the ground?
Blamalam
Mar 12, 2022 07:34 AM
SubiKing
Aug 21, 2021 03:57 AM
WellsR
12
Jul 31, 2015 03:27 PM
itzmywife's
Jul 25, 2015 04:55 PM
Avenged
Jul 9, 2015 07:55 AM
