Tacoma 2.4L X2Rz-N74 99 and Knock Sensor
Old Nov 10, 2011 | 10:37 AM
Alinthedesert's Avatar
5 years ago, I had my faulty Tacoma 2000 2.4L engine replaced with a used one (#2 exhaust valve failed 3x in 1st 90K). Now I need to replace the knock sensor, but no one - not even my local Toyota dealer can tell me anything even about the engine, let alone the sensor! The label on the engine valve cover says... X2Rz-N74 99. The markings on the knock sensor are... "D" (underlined - like maybe Nippon Denso?), P0.2, and 7Df (can't read last character completely - might be t or 1). Even a web search doesn't reveal much, Denso web site says nothing about knock sensors. I'm stumped. I would greatly appreciate any help. Thanks.
Old Nov 10, 2011 | 10:55 AM
Fink's Avatar
I find it hard to believe that the Toyota dealership doesn't have the part number for the knock sensor.
Try a different dealer or go to www.toyotapartsales.com.
Fink
Old Nov 10, 2011 | 11:20 AM
Several options, no part numbers shown
There are two knock sensors listed specifically for nippondenso for the year 2000 (assuming the motor is a 2000, and the knock sensor was consistent throughout the year, which for the original engine, it was not - the dealer needed the VIN to identify the original knock sensor). The list at ToyotaPartSales doesn't give any other identifiers. The dealer said it could be one of 6 different sensors that at least look like the one in question. Thanks.[IMG]file:///C:/Users/Al/AppData/Local/Temp/moz-screenshot.png[/IMG]
Attached Thumbnails Tacoma 2.4L X2Rz-N74 99 and Knock Sensor-knock-sensor.jpg
Old Nov 10, 2011 | 11:35 AM
Fink's Avatar
Get the VIN off the motor and use that to get a replacement.
Fink
Old Nov 10, 2011 | 11:57 AM
Thanks, I assume you mean the engine serial number, which I just read. I will take your suggestion and call another dealer to see if they can get me the correct part number.
Old Nov 10, 2011 | 12:16 PM
Fink's Avatar
No - I meant the VIN. It should be on a machined plate on the front of the engine. This will give you all of the information you need, given that engine-specific information is coded into it.
I'm sure the engine serial number/code would do the same, but using the VIN is a more common method, and will probably be easier to get data from.
Fink
Old Apr 23, 2024 | 03:01 AM
comatt21's Avatar
Hey did you find knock sensor? I’m looking for same one
smthwsn357
May 1, 2024 07:28 AM
tobylab
Dec 3, 2015 08:41 PM
raptor510
Aug 19, 2015 02:15 PM
nonstop
Jul 24, 2015 06:29 PM
smiley52
Jul 11, 2015 05:16 AM
