- Info on 1984-1987 Toyota Diesel 4x4 extra-cab
- Rebuilding motor questions
- Is there a adjustable coilover that will give a good street ride
- Are steering stabilizers worth it?
- Pinging and loss of power
- 2nd Gen rear window problem?
- Dull headlight?
- '85 4 runner: how do i bolt up my torque converter?
- how hard to.......... or whats it cost?
- CEL and the MAF
- Changed 4Runner
- People cant drive
- tons o maintenance done, and truck is running goooooooood
- Light bulb help!
- type of gear oil
- Help on O2 sensor Install (questions on Bobs writeup)
- backspacing?
- I've got that sinking (brake pedal) feeling..
- Aftermarket gas caps
- CV boot kit
- Gas mileage
- Re-lamped my 3rd gen. Runner w/ Plug-n-Play LED bulbs
- Difficulty of a ring and pinon install
- coilovers with spacers
- help with car alarm issue
- Rear Window Problem Update
- OME's or Downey?
- Shifting from 4HI to 2HI?
- Got Stuck...Had Fun *pics*
- 22re cam swap HELP!!!
- Monroe SensaTrac Owners....Speak Up
- new user needs engine swap help (3.4)
- new set up im thinking abuot...
- Pre and Post OME Lift Pics
- Annoying Starting Problem...please Help!!!
- Question for the site admin...
- Stubborn tailgate window (94 Runner)
- Switching out the standard temp controls with the limited temp controls.
- 4 runner 3.0l 96 automatic
- 2005 Tacoma
- wierd sound (clutch and whinying): help diagnosis needed
- pcv valve
- California emissions question
- Super 40
- ADD problems
- cold start solenoid
- Online Vehicle Repair Guides
- 3.0 Downey Headers Done and I ain't Makin' Torque
- One stop shopping
- Dark grey sludge under the oil cap...
- Shifter Bushing MIA!
- Access cab or regular cab
- Progressive coils???
- Exaust Question
- 3vze valve shimming.....mother of GOD!!! - intake plenum question...
- Jumping The Gun
- How to remove speedo please
- Oil change dilemma
- downey coils ??
- 2nd gen Rear Coil Isolators?
- Air Conditioning Kit Install
- Questions about my new truck
- 86 4runner bad rebuilt 22re HELP?
- To those of you with NE spacers and a rear squeek
- How much does rear top weigh?
- Transmission Revisited...d
- cornfed or bodylift
- Driveline Noise when in 4wd
- Miles...?
- 95.5 Tacoma
- gas mileage
- How's This OME Setup?
- Anyone using the KYB AGX shocks?
- Steel or All Cast?
- Supra AFM in a what?!?!
- New Trucks Emblem
- Added LATCH top tether on 2nd Gen.
- Rattle in the rear
- 94 4Runner - need some insight
- looking to buy...
- Seafoam Trans-Tune
- hepl i need a more detailed manual
- Looking for High Desert wheeling spot...
- crank pulley tool
- DXD Clutch Write Up
- Will this wire scheme work?
- keep the 4runner or buy a taco?
- What are these?
- 2nd gen sag?
- My Clutch is springy
- Largest tires that will fit my stock 82?
- Give me the low down on lift kits !
- 3.0 help
- Next mod to make?
- Downey Exhaust Install
- When did the TRD option start?
- 93 4Runner question
- Performance chip module
- Noisey lifter in newly rebuilt 3.0
- 2nd Gen rear window switch
- tundra lift setup
- 10 years, 140k+ miles, first stranding...
- Ah help! Oil extremely overfilled and the ensuing drama!
- Front bearing question
- optima battery
- Accessing Tailgate...
- For all you 79-83 officionados...
- Cooling hose help needed ASAP!!
- Rebuilding a sway away coilover
- Got my brakes inspected today....
- Check Engine Light - How to Clear it
- 3VZE Igniter Help
- Yes I'm Slow! Finally posting some pics.
- Newbie ?
- Fuel leak???
- Suggestions on what to buy**Newbie Alert*
- Anyone In the MA Area To Help with OME Install?
- Check engine light issues
- My 1997 3.4 Liter 4 Runner Broke Down On Way To Work, Please Help!!!!!
- 3.4 Engine Removal Help
- How to complete flush and do a complete transmission fluid change.
- Size/thread of plug for transmission pan?
- I've got issues... such as a 1/2" Tundra coil lift and 13mpg... read please....(long)
- v6 knock sensor bad?
- 22re high, hunting idle IACV?
- Help with some brakes
- Wifes new 3rd Gen
- Downey 1.5HD rear coils are on!
- Windshield washer sprayer question?
- How many 1st gen Tubro out there?
- check out this rear bumper
- driver side red door light 1994 4runner
- Need a fender flare part.
- Making my own shackle hangers
- Help pleasee!
- B&M Tranny Cooler Question
- 22re clutches
- PP1 pics on 4runner anyone??
- Engine Decal for the 3.4?
- Progress of my truck *lotsa Pics*
- Running on 5 cylinders?
- Upgraded Headlamps from Burtman Industries
- Soft brakes
- Wifes new yota!!
- MPG increase w/ manual hubs ??
- how to find geaing??
- Anyone have a 2000 Tacoma Ignition Wire Diagram?
- Installing an Optima Red Top model 34/78 in a '99 Tacoma
- WRANGLER speaker bar in 1st gen 4runner?
- Ball joint spacers???
- Transmisssion
- ARB Winch Bumper For 3rd Gen 4Runner Update
- Coil spacers?
- When removing e-locker
- mile per galon
- 22re Automatic Shifting late.
- 2004 tacoma wheel bearings
- OME Leaaannnnnnnnnnnnnnnnn -
- wrecked SC'd 4runner
- Power steering exploded!
- 3rd gen tire fitting
- Diffrence in steering box Years??
- Air filter ?
- Swapping Toyota 1GR-FE (4.0L V6) in place of a 3VZ-E( 3.0L V6)
- bad wheel bearing sound, new wheel bearings?
- Difference between 22r and 22re (for my 82)
- brake question
- Maybe a stupid question about Engine swaps?
- Another clutch Q
- Lift for 83
- What is a good pick for my first truck/SUV?? Mainly between the 60-ser. LC & 4runner
- Interested 25% off HO alternator?
- Need some advice
- Engine out and apart..22RTE
- One thing after another...
- DRL problem solved, new issue with culprit.
- 3rd gen e-locker wont engage.
- quick question
- Stock gearing??
- Suggestions Buying New Bumpers
- Shipping damage?
- Rear Leaf Spring Bushing Swap
- Bilstein shocks...
- Have you built some storage boxes for your picup bed ?
- Rear end clunk (not axle wrap?)
- Mounting Hella 550's on roof rack
- Cross Country trip done
- SAS Info plz!!
- OME Trim Packers, with OEM
- Who has a " TRD Offroad " 4runner :D check mine out....
- 92 4Runner Starter
- Confused Noob Question
- mechanical fuel pump
- 1st Gen Leather Seats
- Spare tire jack/arm
- My moding begins
- Split Second FTC-1
- anyone fit a FROR bumper on 82 truck?
- #4 Solenoid Location A340H
- power steering sensor?!?
- axle questions
- SICK "AFTER" PICS OF TOYOTAS!
- Happen to anyone else?
- all the parts are finialy installed... check it out. *pics *
- Brake dust sucks -- What new pads should I get?
- Tacoma front wheel bearings?
- Rough idle at low RPM after carbon cleaning... help please...
- Centramatic Wheel Balancers
- Auto Tranny leaking from bell housing...torque converter seal the likely culprit?
- Tundra shock Application on 4runner.
- Tranny Went AGAIN.... :(
- Got stuck.[pics]
- TJM sizing question
- tacoma lift options?
- Oil Pump Q's
- HELP Please...
- I think my syncros are going?
- aamco?
- 98 4Runner with 2001 mods on Ebay???
- Truck Selling Tips Wanted (Please)
- Anyone use " Equal" in their tires instead of Lead weights ???
- question bout coil spacers
- Urgent Question, wheels offsets etc
- 1st gen rear diff leak
- Why no SAS kits for 96 and later?
- Stock trailer wiring have reverse?
- another shock question : Procomp es9000?
- new shop opening in southern indiana in may
- How much Power can be made N/A w/ 22re?
- Tacoma bumper question
- Keep it? Or Sell it?
- HELP.. Need stock length rear springs FIRM
- 3vze header/hg question??
- Oh NO, not another S/C QUESTION!
- gearing question
- Mobil1 Extended Performance
- help my truck has a weird miss
- Shackel hangers w/ TJM????
- Another 3rd gen 4runner LIFTED!! Pics inside!
- Installing new struts/shocks..Is it a do it yourself project or professional only?
- rebuilt tranny
- Es Problema?
- 350 swap fuel question
- Engine Backfire
- What fits?
- LED turn signals in a 4 Runner???
- Question about lifts?
- look what goes on the truck tomorrow *pic*
- Rear disc brakes
- pic of my custom gage layout
