Soft brakes
Old Mar 2, 2005 | 02:22 PM
Ontario's Avatar
Soft brakes
This is a great site. Recently bought a 94 4-Runner - everything is stock.
Driving around today, the brake pedal started to feel a little soft. Slowly pumping the pedal, it felt as though it was sinking further and further down. Although I never lost my brakes the signs seem suspicious. To further complicate things, the brake fluid resevoir is still full and the fluid level has not changed.
Am I imagining things or is there another explanation for the sponge-like brake pedal?
Thanks
Ken
Old Mar 2, 2005 | 03:03 PM
dragon564's Avatar
AIR in the system and master cyl failing can cause the soft pedal yet the whole system could pass a visual inspection.....try bleeding the system first....
Old Mar 2, 2005 | 03:21 PM
Tacoma Dude's Avatar
Ditto dragon's post.
Do you know if the 4runner had any brake service before you took the keys?
Old Mar 2, 2005 | 04:36 PM
Ontario's Avatar
No workorders or maintenance documents on the brakes. But looks as though the brake master cylinder is pretty new. Prior to buying the truck, I had a mechanic check out the brakes (almost 3 months ago), he also mentioned that the master brake cylinder looked new as well.
Anyways, bleeding the brake lines seems to be the best bet.
Thanks guys...
Cheers
Old Mar 2, 2005 | 06:46 PM
switchback's Avatar
Same thing was going on with my Runner when I bought it a few weeks back. I had the system flushed and bled and it is all perfect now. It made a world of difference too! Won't cost much to do and you'll be happy you did. Enjoy your new truck!
Old Mar 2, 2005 | 06:53 PM
terky's Avatar
Its the master i would bet, I replaced mine for the same reasons. Really easy actually.
Old Mar 2, 2005 | 08:59 PM
Cardesign's Avatar
adjust yr rears also. with the brake spoon.
Old Mar 2, 2005 | 10:37 PM
Alin10123's Avatar
It sounds like you have some really old fluid in the lines. Either that or there's air in the lines. Like everyone said before me, bleed and flush the system and you should be good to go. I posted a post a couple of months back about where to get a good price for a "motive power bleeder". Search for the post and you should find the good price. I think it was like $45 w/ free shipping.
also read this webpage about more brake flushing info.
http://www.gadgetonline.com/BrakeFlush.htm
Pay special attention to the "power bleeding" section.
Old Mar 3, 2005 | 12:46 PM
Ontario's Avatar
Thanks for all the suggestions guys...
Did I mention this was a great site?
Ken
nvdesertrunner
May 11, 2020 08:18 PM
Mudlover
Sep 2, 2015 03:50 AM
bfmcelroy
Aug 18, 2015 06:42 AM
94ofCanada
Aug 14, 2015 06:37 AM
CanRunner
Jul 20, 2015 01:29 PM
