Give me the low down on lift kits !
Old Mar 3, 2005 | 06:16 PM
pfbmgd's Avatar
I`m looking to maybe lift my 4runner 2 inches .I have some questions that I couldn`t answer with a search .
What kits are good ? What`s in a kit ?
How much to install ?
Will I have to do a 4 wheel alignment ?
Will I have to replace the shocks ?
Can my poor 2.7L 4 cylinder handle the change ?
How badly will my mileage suffer ?I will not be changing the tires or rims .
Any other advice apreciated .I will not be doing much off roading .I`m just doing it for looks .
Old Mar 3, 2005 | 06:44 PM
dragon564's Avatar
Search some more plenty of info here about lift kits and getting them installed. Also Rodger Brown has good info...I I have one of his 2 inch kits on mine..
here is the link:
http://www.4crawler.com/4x4/ForSale/BodyLiftKit.shtml
Old Mar 3, 2005 | 06:51 PM
Tacoma Dude's Avatar
A complete kit is just that. Everything you will need to lift your vehicle. It may not account for other things - such as the possible need for an extended brake line.
Prices vary.
You'll need an alignment if it is a suspension lift.
Depends on type of lift.
Probably.
It will suffer. Depends on how much lift. Probably could expect to lose 1-3 mpg.
Once you've determined if you are going to get a body lift or a suspension lift the searching will be much easier. You may also want to search using different keywords. A lot of this is stuff you will find in a search.
Trust me, if I know it then it's something you can find in a search. Just about all the stuff I know about my truck I learned here
Old Mar 3, 2005 | 06:52 PM
Also, follow this link. It's mainly for Tacomas but the front end stuff should be applicable.
http://www.customtacos.com/tech/inde...v2&id=137&c=10
Flying91
45
Apr 11, 2024 04:39 PM
Eggslinger
Jun 8, 2019 03:32 PM
Sep 4, 2015 09:27 AM
Coreyr384
Jul 10, 2015 11:13 AM
MTLroadierunner
Jul 6, 2015 12:17 PM
