Difference between 22r and 22re (for my 82)
Old Mar 2, 2005 | 01:55 AM
futurerunner's Avatar
I have a 82 long bed with a 4 speed manual with a 22r motor. The motor has issues. Anyway, thinking down the line, can I swap for a 22r motor like this one ? http://cgi.ebay.com/ebaymotors/ws/eB...649&category=0
It seems more cost effective to go with the 22re than to build up a 22r.
So what are the difference between the two ?
C
Old Mar 2, 2005 | 07:16 AM
Stegall984R's Avatar
From: OmG, Hi2U !!! .... DANG, my chic's got some SEXY eyes.... among other things. WOOT WOOT !!
R is carbed, RE is fuel injected. Other then that, nothing. you could buy the RE engine, but unless u have the ecm and wireing harness for it you cant use it. You could still buy that engine though, and put your intake manifold w/ the carb on it and be good to go.
Edit : after looking at the engine in that auction, it wouldnt matter. It dosnt come with any manifolds any how. You can probably find a good engine in a salvage yard some where for less then half that one, that would probably serve you just as well.
Old Mar 2, 2005 | 09:26 AM
wimpywade94's Avatar
WRONG,
the re block is differnt,
if you look at the old r series block head and pistons, they have dome topped, lower compression, the block is quite a bit shorter then a re block is to,
if you get an re block even without fuel injection, you can build it with some seriouse power compared to a r series,
the old r series was just a tractor motor, ran forever, but not much to build power on.
wade
Old Mar 2, 2005 | 11:57 AM
hmm.
whoops.
Old Mar 2, 2005 | 05:24 PM
kyle_22r's Avatar
you're also partly wrong. 22R and 22RE are EXACTLY THE SAME as long as they're either '84 and older or '85 and newer. the early engine('81-84) had round exhaust ports, a "tall" head and "short" block with open combustion chambers and volcano domed pistons. the late engine('85-95) had pear shaped exhaust ports, flat top pistons and closed combustion chambers. the only way to tell between the blocks is to look for a flying saucer shaped mark on the driver's side which means that it's a late block. the deck height difference is only 3mm anyway between early and late, you can bolt an early head and timing cover/chain/oil pump/etc on a late block if you get that 3mm machined off.
also, '81 and '82 22Rs aren't compatible with the EFI manifold since they aren't tapped for it -- the 22RE came out in '83.
to answer the original question, a 22R intake manifold will swap directly onto any '81-95 22R or 22RE long block. might have to change the exhaust manfold, though.
Old Mar 2, 2005 | 06:55 PM
Once again, I am ever so greatful to this board.
Old Mar 3, 2005 | 05:59 AM
ok kyle, you got me, even though thats what i said, but without being fancy and using dates, the old r block is shorter, with domed pistons, the new block is taller, with flat top pistons, better engine, better heads, more power,
wade
Old Mar 3, 2005 | 07:29 AM
kyle_22r's Avatar
yeah, but a lot of guys don't know the 22RE was also made before '85 and the 22R was made after!
Old Mar 3, 2005 | 07:51 PM
i see your knowlege of toyota vastly outnumbers mine.
we should duel.
wade
Old Mar 3, 2005 | 07:52 PM
WOHH hold the horns little buddy,
can the 22re block bolt to the 4 speed?
not sure if it will or not, whadda you know kyle?
wade
Old Mar 3, 2005 | 08:04 PM
03_4x4Runner's Avatar
the boot patterns on the backs of the blocks are the same, just the deck height was changed, so it should be good
Old Mar 4, 2005 | 07:23 AM
kyle_22r's Avatar
ALL R blocks to my knowledge have the same tranny pattern, 22R, 22RE, 20R, 18R etc...
Old Mar 4, 2005 | 08:08 AM
DudeBud's Avatar
true but do you really want to run that 4spd
Old Mar 4, 2005 | 10:11 AM
yeah, that was my second point in question....
i thought something was differnt on them to though, mabey its for 2 wd's or something.
i dunno.
wade
Old Mar 4, 2005 | 01:32 PM
kyle_22r's Avatar
no differences between the pattern between 4wd and 2wd, early, late etc
the 4 speeds in 82 were the "decent" 4x4 4 speeds. 4x4s never got the "better" 4 speeds like the G40 since they all went to 5 speed after '82
cars-guy
Aug 16, 2020 06:59 AM
dumpster84
Apr 30, 2016 06:03 AM
deepmarsh
Aug 6, 2015 03:44 AM
cars-guy
Jul 11, 2015 07:51 PM
Huntingtruckcletus
Jul 8, 2015 05:26 PM
